I have a wire modem attached to my Gli router that won’t take remote commands over lan, the only way to get it to reboot is to disconnect the USB charger.
Is there a way for me to schedule periodic disconnects of the USB charger, so my modem resets on a set interval so I don’t have to manually unplug it?
I don’t see any “free” GPIOs at GL-B1300 (Convexa-B) - GL.iNet Docs (to control a relay for the USB power) or an indication of GPIO-controlled USB power. The DTS does not suggest that there’s a GPIO hog or fixed-voltage regulator in place.
GL-S1300 (Convexa-S) - GL.iNet Docs shows a couple GPIO lines available. Based on that I’d go with a relay spliced into a USB cable. I’ve never torn apart a USB-C cable, but if it’s “just power” then a “normal” cable would work as well.
As a different option:
Perhaps something like a TP-Link HS105 being controlled by the pyHS100 (Python) library? (Keep them off the Internet, as they are overly chatty with their cloud server, even if you’ve “disabled” it.)
Similar to @jeffsf, I have several TP-Link HS103 smart plugs that turn off/on to reboot some of my network devices. They can be scheduled daily/weekly at multiple times through the TP-Link Kasa app.
The schedules are stored on they smart plugs themselves and the Kasa app is only for setup/configuration/monitoring. I don’t have the problem, but if you REALLY do not want them to connect to the Internet, then create an wireless SSID dedicated to them that you can turn on/off only when you want to use the Kasa app.
