[script] IMEI changer
Hi :wave:
I decided to write this script to help with anonymity and bypass ISP restrictions
Copyright:
You are free to use/edit/share script, but always put link to this thread and/or GitHub page
GitHub page
Here
Scripts
Not to overflood thread hidden under spoiler:
V1
#!/bin/bash
echo "Choose an option: 1) Set auto-update of IMEI on boot 2) Change IMEI once 3) Remove automatic change of IMEI"
read -p "Enter your choice (1, 2, or 3): " user_choice
case $user_choice in
    1)
        echo "Setting auto-update script..."
        cat << EOF > /etc/init.d/auto_update_imei.sh
#!/bin/bash
luhn_checksum() {
    local num=\$1
    local sum=0
    local num_length=\${#num}
    for ((i=num_length-1;i>=0;i--)); do
        local digit=\${num:i:1}
        if ((i % 2 == 0)); then
            ((digit *= 2))
            if ((digit > 9)); then
                ((digit -= 9))
            fi
        fi
        ((sum += digit))
    done
    local check_digit=\$((10 - (sum % 10)))
    if ((check_digit == 10)); then
        check_digit=0
    fi
    printf "%d" "\$check_digit"
generate_valid_imei() {
    local prefix="\${imei_prefix[\$RANDOM % \${#imei_prefix[@]}]}"
    local suffix=\$(printf "%08d" \$((RANDOM % 10000000)))
    local full_imei="\${prefix}\${suffix}"
    local check_digit=\$(luhn_checksum "\${full_imei}")
    printf "%s%s" "\${full_imei}" "\$check_digit"
declare -a imei_prefix=("35674108" "35290611" "35397710" "35323210" "35384110"
                        "35982748" "35672011" "35759049" "35266891" "35407115"
                        "35538025" "35480910" "35324590" "35901183" "35139729"
                        "35479164")
SET_IMEI() {
    local imei="\$1"
    if [[ \${#imei} -eq 15 ]]; then
        gl_modem AT AT+EGMR=1,7,"\${imei}"
    fi
start() {
    local imei=\$(generate_valid_imei)
    SET_IMEI "\$imei"
stop() {
EOF
        chmod +x /etc/init.d/auto_update_imei.sh
        /etc/init.d/auto_update_imei.sh enable
    2)
        read -p "Change IMEI automatically or provide a custom one? (auto/custom): " imei_option
        case $imei_option in
            auto)
                imei=$(generate_valid_imei)
                echo "New IMEI: $imei"
            custom)
                read -p "Are you sure you want to set a custom IMEI? (y/n): " confirm_custom
                if [[ "$confirm_custom" == "y" ]]; then
                    read -p "Enter your custom IMEI: " custom_imei
                    echo "New IMEI: $custom_imei"
                else
                fi
                echo "Invalid option."
                exit 1
        esac
    3)
        echo "Removing auto-update of IMEI..."
        rm /etc/init.d/auto_update_imei.sh
        echo "Invalid choice."
        exit 1
esac
luhn_checksum() {
    local num=$1
    local sum=0
    local num_length=${#num}
        local digit=${num:i:1}
            ((digit *= 2))
                ((digit -= 9))
            fi
        fi
        ((sum += digit))
    done
    local check_digit=$((10 - (sum % 10)))
        check_digit=0
    fi
    printf "%d" "$check_digit"
    local prefix="${imei_prefix[$RANDOM % ${#imei_prefix[@]}]}"
    local suffix=$(printf "%08d" $((RANDOM % 10000000)))
    local full_imei="${prefix}${suffix}"
    local check_digit=$(luhn_checksum "${full_imei}")
    printf "%s%s" "${full_imei}" "${check_digit}"
                        "35479164")
V2
#!/bin/sh /etc/rc.common
START=99
STOP=99
luhn_checksum() {
    local num=0
    local nDigits=${#1}
    local odd=$((nDigits % 2))
    for ((i=nDigits-1; i>=0; i--)); do
        local digit=${1:$i:1}
        if ((i % 2 == odd)); then
            ((digit *= 2))
                ((digit -= 9))
            fi
        fi
        ((num += digit))
    done
    echo "$num"
luhn_digit() {
    local num=$(luhn_checksum "$1")
    echo $((10 - (num % 10)))
is_valid_luhn() {
    ((num % 10 == 0))
    local suffix=""
    for ((i=0; i<6; i++)); do
        suffix="${suffix}${RANDOM: -1}"
    done
    local check_digit=$(luhn_digit "${full_imei}")
    echo "${full_imei}${check_digit}"
SET_IMEI() {
    local imei="$1"
    if [[ ${#imei} -eq 15 ]]; then
        gl_modem AT AT+EGMR=1,7,"${imei}"
    else
        echo "Invalid IMEI length."
    fi
                        "35479164")
start() {
    local imei=$(generate_valid_imei)
    SET_IMEI "$imei"
stop() {
How to use it?
V1
Just run it :slight_smile:
V2
  1. Put it into
 /etc/init.d/
  1. Make executable
chmod +x /etc/init.d/imei_randomiser.sh
  1. Enable
/etc/init.d/imei_randomiser.sh enable
IMEI.info: The Check Digit is a function of all other digits in the IMEI. The purpose of the Check Digit is to help guard against the possibility of incorrect entries to the CEIR and EIR equipment.
Example:
IMEI.info: IMEI: 35145120840121
  1. (5x2, 4x2, 1x2, 0x2, 4x2, 1x2, 1x2) = (10, 8, 2, 0, 8, 2, 2)
  2. (1+0+8+2+0+8+2+2) + (3+1+5+2+8+0+2 ) = 44
  3. Luhn Digit : 6
IMEI: 351451-20-840121-6
I cannot see how in your scripts you are confirming the Luhn Digit?
If you present an invalid IMEI to any equipment that correctly checks for the Luhn Digit you will be blocked and blacklisted.
Fixed logic a little. I was testing it in virtual environment, so missed this part.
Hope now everything will work well :slight_smile:
