I'm experiencing the same micro SD card detection issue reported in the 4.8.2/4.8.3 threads, but on firmware 4.8.4.
Symptoms:
- No
/dev/mmcblk0device appears in/proc/partitionsafter inserting the card - No kernel messages logged on hot insertion (
dmesgstays empty) - Tested with two different SD cards (different brands/capacities): same result with both, ruling out a card-specific issue
- Card-detect GPIO works correctly (
Got CD GPIOappears in dmesg after driver rebind) - SDHCI controller initializes fine (
mmc0: SDHCI controller on 7804000.sdhci_sd using ADMA 64-bit) - Manual driver rebind produces:
mmc0: error -110 whilst initialising SD card
What I checked:
root@GL-AXT1800:~# dmesg
[ 632.067569] sdhci_msm 7804000.sdhci_sd: Got CD GPIO
[ 632.067642] sdhci_msm 7804000.sdhci_sd: allocated mmc-pwrseq
[ 632.071297] sdhci_msm 7804000.sdhci_sd: sdhci_msm_get_ice_device_vops: ICE device is not enabled
[ 632.221872] mmc0: SDHCI controller on 7804000.sdhci_sd [7804000.sdhci_sd] using ADMA 64-bit
[ 632.243032] mmc0: error -110 whilst initialising SD card
- Card-detect GPIO and controller probe both work (
/sys/class/mmc_host/mmc0/present,readlink -fshows7804000.sdhci_sd, driversdhci_msm) - Manual unbind/bind of the driver reproduces the same
-110timeout every time - USB storage works perfectly fine on the same unit — this appears isolated to the SD card path
Confirmed workaround: Downgrading to 4.6.11 would likely resolve this based on other reports in the 4.8.2/4.8.3 thread, but I wanted to flag that this regression is still present in 4.8.4, so it hasn't been fixed yet in the stable branch.
SD cards tested:
- Amazon Basics SD 512Gb
- 4Gb SD Card (cannot remember the brand right now)
Happy to provide GoodCloud remote access if that helps investigate further, as offered in the other thread.
Thanks!
