Currently my ssh, web ui and the WiFi AP use same password. I am wondering if there is a way to setup different password for WiFi AP.
Thanks
Thanks
For ssh, you can ssh to the router and use passwd to change.
For UI you can change in then UI later.
For WiFi, you can change it in the UI as well.
They will be different.
just change the password in the UI’s wireless settings.
ssh password can be changed using ssh
UI password can be changed using the the UI’s access page.
