I just opened my GL-AXT1800 Slate. No where on the bottom label can I find a password. I’ve tried admin and Admin with no success. Also do I need a separate travel modem for it? Thank you!
Found the password but can’t complete the set up.
If this is not the case I suggest a reset:
Power on router
Hold reset button (light will flash)
Hold reset button (light will flash faster)
Hold reset button (light will flash even faster) release reset button.
The password you have found is for the SSID, not the router.
You need to set up a new password for login. The password on the bottom sticker is the WiFi Key, as it is labeled.
Thank you, I will try that. So frustrating.
