Setting of GL-AR300M's DHCP server
as you can see in the this image
there is some client with ip assigned from dhcp server router.
But in dhcp configuration file there is:
config dnsmasq
option domainneeded '1'
option boguspriv '1'
option filterwin2k '0'
option localise_queries '1'
option rebind_protection '1'
option rebind_localhost '1'
option local '/lan/'
option domain 'lan'
option expandhosts '1'
option nonegcache '0'
option authoritative '1'
option readethers '1'
option leasefile '/tmp/dhcp.leases'
option nonwildcard '1'
option localservice '1'
option resolvfile '/tmp/resolv.conf.vpn'
config dhcp ‘lan’
option interface ‘lan’
option start ‘100’
option limit ‘150’
option leasetime ‘12h’
option force ‘1’
option dhcpv6 ‘server’
option ra ‘server’
config dhcp ‘wan’
option interface ‘wan’
option ignore ‘1’
config dhcp ‘guest’
option interface ‘guest’
option start ‘100’
option limit ‘150’
option ra ‘server’
config odhcpd ‘odhcpd’
option maindhcp ‘0’
option leasefile ‘/tmp/hosts/odhcpd’
option leasetrigger ‘/usr/sbin/odhcpd-update’
option loglevel ‘4’
config domain ‘localhost’
option name ‘console.gl-inet.com
option ip ‘192.168.1.8’
As you can see the assigned ip client is not in the range 100-150. What is wrong?
BR
The range is 100~250,start 100 and limit 150
