SF1200 interface with 802.1Q, VLAN ID 10 help
Hello GL.iNet
I have an instruction from my provider to setup my router as follows
WAN Connection: DHCP
802.1Q: Enabled
VLAN ID (802.1Q): 10
802.1P (Priority): 0
IP Version: IPv4 or IPv6
MTU Size: 1492 or 1500
NAT: Enabled
I cannot find it via search so I am hoping this topic will not get flagged as an annoying one.
I am sure this is simple enough to configure and I am hoping a kind soul can help me with my problem.
Thanks a lot guys!
Does the GL-SF1200 router have a LuCI → Network → Switch page where you can set up VLAN?
Thank you for responding @wcs2228 .
Yes. I have Luci installed.
I am reading OpenWRT on creating interface and setting up VLAN like Eth1.10
I am hoping there’s an existing guide or documentation for this configuration.
If you have any more idea how to do this please share to me.
Maybe this will help:
https://chrismolloy.com/p216.php
@wcs2228 Thanks a lot! This is what I am looking for.
This should fix everything. Thank you.
