anyone interested in testing an initramfs image?
I'm up
I should be able to get this across to you this weekend.
I was wondering if there were any updates on the Openwrt updates ![]()
Using the Openwrt image maker I noticed there was the option to compile an image for the siflower SF19A2890.
I just had to try making it and flashing it to my opal.
But I was unable to connect to it after flashing, so had to reinstall orig firm via uboot.
Trying to compile it again I went looking for the network drivers, and did not find any..
I think, since I am just a novice.
I would really like to run the latest Openwrt on it, so if I can help by testing anything let me know.
There seems to be no progress since February
Is there any chance we'll live to see the upgrade?
still no update? never thought opal1200 would not have latest openwrt updates
No update.
https://dl.gl-inet.com/router/sft1200/beta
4.7.2 beta (version 2) is the latest so far. Dated 2025-04-21 it is an important improvement of the earlier 4.7.2 beta version 1. They improved some things in the SF19A2890 driver, and it starts now to be usable.
There are still some problems in the 5GHz (no DFS possible), but those are all things that depend on the SF19A28 driver (Siflower driver specific) , not on the OpenWrt version. So OpenWrt 18.06 or not is not the most important limitation for the SFT1200/OPAL.
Lets see when there is something new from GL.inet. I'm using mostly Cudy TR1200 now and this is also OpenWRT 18.06, but without problems, with good performance.
I ended up buying a Cudy TR3000, I should have done more research on this particular device & GL.iNet, mainly whether it was upstreamed to OpenWRT. The next stop for the SFT1200 is probably an electronics recycler.
true. i thought SFT1200 will get latest Openwrt. at least 20 version
yeah, i should have done more research before purchasing sft1200. main purpose i bought it to configure v2ray.
Feels like a dead end here
I bought a new Opal just today, after reading on the website that it supports OpenWRT, but it’s really disappointing that it’s a 7 year old release, making me question how safe using this actually is, and whether I’d be better off without it. As I imported it, I cannot really return it without excessive costs, so I’m not sure what would be best for me to do here.
Are there any news on newer OpenWRT releases?
Thanks!
cc @bruce
Given the limited R&D resources of the manufacturer, driver adaptation is difficult, I think we cannot (difficult to) see the Vanilla OpenWRT firmware for Opal.
But for the security of the currently latest firmware, please rest assured to use it.
Based on its current OP version, we apply patches to ensure that the system does not have high-risk vulnerabilities. As long as you follow the firmware upgrades, it will quite safe.
I’ve been working on the DSA driver for more recent MaxLinear GSW1xx chips and found out that it can easily support GSW150 as well. So most likely, Linux 7.0 is going to have a DSA driver for the PEB7084. If anyone can provide me with the SiFlower router hardware I can make sure that it will work fine for that as well.
Thanks for your research!
What information would you like us to provide?
@bruce The sourcecode of the WiFi driver would be great, as that is going to be the one missing piece in the puzzle now to allow running this on vanilla OpenWrt. The blobs look a bit like the WiFi is re-branded Broadcom stuff…?
@dangowrt has asked for the hardware, so if a sft1200 could be sent to this core Openwrt developer…
