SFT1200 2.4 GHz Repeater Disconnects
root@GL-SFT1200:~# cd /sys/kernel/debug/ieee80211/phy1/siwifi
root@GL-SFT1200:/sys/kernel/debug/ieee80211/phy1/siwifi# cat trx_stats
dump trx status
mpdu last rx 0
mgmt rx 97944
spurious rx 398
delete rx 0
monitor rx 0
len_update rx 0
rxdataind 336263
rx mpdu missed 183499
rx ldpc 171920
rx bcc 52762
rx stbc 0
ipc pending cnt 0
mpdu tx retry 264954
single tx retry 193
mpdu tx failed 285591
mpdu tx flush 0
mpdu tx discard 0
tx copy expand 1564
tx drop full 0
tx drop sta null 291
tx drop inactive 0
tx drop hdr fail 0
tx drop prepare 0
VIF[0]: wlan1
RX bcn: 97300 non: 0 ft: 0 mgmt: 643
mgmt-tx: 1010
mgmt-tx-drop: 18
VIF[2]: wlan-sta0
RX bcn: 95003 non: 0 ft: 0 mgmt: 458
mgmt-tx: 0
mgmt-tx-drop: 0
root@GL-SFT1200:/sys/kernel/debug/ieee80211/phy1/siwifi# cat stats
TXQs CFM balances [0]: 0 [1]: 0 [2]: 0 [3]: 0 [4]: 0
queue stop [17] start [17]
AMSDU[len] done failed received
[ 0] 256942 0( 0%) 210640
[ 2] 0 0( 0%) 8010
[ 3] 0 0( 0%) 2064
[ 4] 0 0( 0%) 732
[ 5] 0 0( 0%) 434
[ 6] 0 0( 0%) 318
[ 7] 296
[ 8] 242
[ 9] 122
[10] 116
[11] 146
[12] 154
[13] 316
[14] 86
[15] 92
[16] 63
[17] 58
[18] 60
[19] 45
[20] 54
[21] 50
[22] 45
[23] 31
[24] 40
[25] 31
[26] 40
[27] 47
[28] 33
[29] 38
[30] 43
[31] 45
[32] 871
AMPDU[len] done received
[ 0] 14673 46275
[ 2] 1873 503
[ 3] 571 238
[ 4] 295 163
[ 5] 209 96
[ 6] 180 83
[ 7] 231 55
[ 8] 175 34
[ 9] 140 36
[10] 123 40
[11] 111 32
[12] 113 23
[13] 130 25
[14] 167 23
[15] 114 24
[16] 154 26
[17] 153 22
[18] 266 21
[19] 130 28
[20] 193 22
[21] 94 112
[22] 1102 116
[23] 237 138
[24] 101 78
[25] 90 53
[26] 108 30
[27] 108 9
[28] 105 19
[29] 192 26
[30] 635 11
[31] 472 7
[32] 148 14
[33] 693 9
[34] 755 28
[35] 173 20
[36] 70 7
[37] 60 16
[38] 52 12
[39] 30 7
[40] 28 9
[41] 20 7
[42] 29 8
[43] 21 11
[44] 26 19
[45] 27 14
[46] 183 26
[47] 38 15
[48] 29 18
[49] 15 25
[50] 12 140
[51] 7 193
[52] 14 73
[53] 10 22
[54] 10 31
[55] 19 28
[56] 8 247
[57] 7 98
[58] 10 45
[59] 3 31
[60] 15 9
[61] 12 7
[62] 34 6
[63] 23 5
[64] 289 5023
well at least some >31 get done now.
'Done' is what here ???
Thanks for your reply, “done” means the number of packets sent by AMPDU. I did not reproduce the exception log lmac[1] Error, msdu index reach maximum limit, 31. Could you please provide me the topology on your side and the configuration of the parent MikroTik, I'll try to reproduce it, thanks!
OK so done = sent , that makes sense. Now we do sent AMPDU with more MPDU.
Reception max counter seams unrelated (what it should be, but should allow for the max defined in the IEEE802.11ac standard)
Not all lines of the wAP ac device config are relevant. But I know in testing there is never enough detailed information. "nv2" and "nstreme" is not used here. And the multicast-helper=full was because of previous multicast problems/tests.
Only priority is 0, so ampdu setting for 0 is he only one active (no packets for ampdu 1,2,3,4,5 in the data stream)
[admin@MktwAPac] /interface wireless> export
dec/31/2024 11:30:11 by RouterOS 6.49.13
software id = edit
model = RouterBOARD wAP G-5HacT2HnD
serial number = edit
/interface wireless channels
add band=5ghz-onlyac extension-channel=Ceee frequency=5500 list=dfs name=ch100-ch112 width=20
add band=5ghz-onlyac extension-channel=Ce frequency=5500 list=dfs name=ch100-ch104 width=20
add band=5ghz-onlyac extension-channel=Ce frequency=5540 list=dfs name=ch108-ch112 width=20
add band=5ghz-onlyac extension-channel=Ce frequency=5660 list=dfs name=ch132-ch136 width=20
add band=5ghz-onlyac extension-channel=Ce frequency=5580 list=dfs name=ch116-ch120 width=20
add band=5ghz-onlyac extension-channel=Ce frequency=5620 list=dfs name=ch124-ch128 width=20
add band=5ghz-onlyac frequency=5700 list=dfs name=ch140 width=20
add band=5ghz-onlyac frequency=5500 list=dfs name=ch100 width=20
add band=5ghz-onlyac frequency=5520 list=dfs name=ch104 width=20
add band=5ghz-onlyac frequency=5540 list=dfs name=ch108 width=20
add band=5ghz-onlyac frequency=5560 list=dfs name=ch112 width=20
add band=5ghz-onlyac frequency=5580 list=dfs name=ch116 width=20
add band=5ghz-onlyac frequency=5660 list=dfs name=ch132 width=20
add band=5ghz-onlyac frequency=5680 list=dfs name=ch136 width=20
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
add authentication-types=wpa2-psk eap-methods="" group-key-update=30m management-protection=allowed mode=dynamic-keys name=abra supplicant-identity="" wpa2-pre-shared-key=
edit
add authentication-types=wpa2-psk eap-methods="" group-key-update=2h management-protection=allowed mode=dynamic-keys name=bpacrt supplicant-identity="" wpa-pre-shared-key=
edit wpa2-pre-shared-key=edit
/interface wireless
set [ find default-name=wlan1 ] ampdu-priorities=0,1,2,3,4,5 band=2ghz-g/n basic-rates-a/g=6Mbps,12Mbps,18Mbps basic-rates-b="" country=belgium disabled=no mode=ap-bridge
radio-name=wAP security-profile=bpacrt ssid=bpacrt station-roaming=enabled supported-rates-b="" tx-power=20 tx-power-mode=all-rates-fixed wireless-protocol=802.11 wmm-support=
enabled wps-mode=disabled
set [ find default-name=wlan2 ] ampdu-priorities=0,1,2,3,4,5 band=5ghz-n/ac basic-rates-a/g=6Mbps,12Mbps,24Mbps channel-width=20/40mhz-Ce country=belgium disabled=no
disconnect-timeout=10s frequency=5660 mode=ap-bridge multicast-helper=full nv2-cell-radius=10 nv2-preshared-key=nv2mikrotik nv2-security=enabled radio-name=wAPac.5 scan-list=
dfs security-profile=bpacrt skip-dfs-channels=10min-cac ssid=bpacrt_5G station-roaming=enabled tdma-period-size=1 vht-basic-mcs=none wireless-protocol=802.11 wmm-support=
/interface wireless nstreme
set wlan2 framer-policy=dynamic-size
/interface wireless access-list
add allow-signal-out-of-range=30s signal-range=-80..120
add allow-signal-out-of-range=3s authentication=no forwarding=no signal-range=-120..-81
