I’ve now updated to 4.8.3, with “Keep settings” unchecked. I was asked on email to provide a screenshot of the Join Wi-Fi page when it failed, so here it is.
This is the output from the commands you suggested.
login as: root
root@192.168.8.1's password:
BusyBox v1.29.3 () built-in shell (ash)
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -| || | | || || |
|_____|| |||||___||| |____|
|| W I R E L E S S F R E E D O M
OpenWrt 18.06, LEDE
root@GL-SFT1200:~# iwinfo wlan0 scan
Cell 01 - Address: DE:EC:5E:45:6F:E9
ESSID: unknown
Mode: Master Channel: 3
Signal: -58 dBm Quality: 52/70
Encryption: WPA2 PSK (CCMP)
HT Capabilities: HT20 VHT20
Cell 02 - Address: D8:EC:5E:45:6F:E9
ESSID: "12JOHNLEEROADPN"
Cell 03 - Address: 7C:5A:1C:FA:F4:F4
ESSID: "KT Engineering"
Mode: Master Channel: 6
Signal: -52 dBm Quality: 58/70
Cell 04 - Address: D8:EC:5E:45:6F:8F
Mode: Master Channel: 8
Signal: -50 dBm Quality: 60/70
Cell 05 - Address: DE:EC:5E:45:6F:8F
ESSID: unknown
Cell 06 - Address: 98:AA:FC:36:7B:71
ESSID: "Wi-Fi Socket"
Mode: Master Channel: 11
Signal: -39 dBm Quality: 70/70
Encryption: none
HT Capabilities: HT20 HT40
Cell 07 - Address: DE:EC:5E:45:2A:7F
ESSID: unknown
Mode: Master Channel: 5
Signal: -57 dBm Quality: 53/70
Cell 08 - Address: D8:EC:5E:45:2A:7F
Cell 09 - Address: 54:B7:BD:AF:6A:D2
ESSID: "PLUSNET-CWC3GQ"
Signal: -80 dBm Quality: 30/70
Cell 10 - Address: 72:B7:BD:AF:6A:D6
ESSID: unknown
Signal: -82 dBm Quality: 28/70
Cell 11 - Address: 62:8D:26:44:EF:20
ESSID: unknown
Signal: -66 dBm Quality: 44/70
Cell 12 - Address: 60:8D:26:44:EF:24
ESSID: "BT-GTASZ8"
Signal: -73 dBm Quality: 37/70
Cell 13 - Address: 62:8D:26:44:EF:25
ESSID: "EE WiFi"
Encryption: none
Cell 14 - Address: E4:75:DC:C3:23:83
ESSID: "BT-CHATZN"
Signal: -83 dBm Quality: 27/70
Cell 15 - Address: 90:02:18:C5:A7:96
ESSID: "SKYNCBRM"
Signal: -84 dBm Quality: 26/70
root@GL-SFT1200:~# iwinfo wlan1 scan
Cell 01 - Address: 38:A6:CE:62:26:EB
ESSID: "SKYCA5AC"
Mode: Master Channel: 36
HT Capabilities: HT20 HT40 VHT20 VHT40 VHT80
Cell 02 - Address: 4E:50:DD:87:0A:02
ESSID: unknown
Signal: -63 dBm Quality: 47/70
Cell 03 - Address: 60:8D:26:44:EF:23
ESSID: "BT-GTASZ8"
Signal: -85 dBm Quality: 25/70
Cell 04 - Address: 7A:8D:26:44:EF:24
ESSID: "EE WiFi"
Signal: -86 dBm Quality: 24/70
Encryption: none
Cell 05 - Address: 7A:8D:26:44:EF:25
ESSID: "EE WiFi-X"
Encryption: WPA2 802.1X (CCMP)
Cell 06 - Address: D8:EC:5E:45:6F:90
Mode: Master Channel: 44
Signal: -47 dBm Quality: 63/70
Cell 07 - Address: 7A:8D:26:44:EF:27
ESSID: unknown
Cell 08 - Address: D8:EC:5E:45:6F:91
Mode: Master Channel: 100
Signal: -48 dBm Quality: 62/70
Cell 09 - Address: D8:EC:5E:45:6F:EB
Signal: -53 dBm Quality: 57/70
Cell 10 - Address: FA:8F:CA:89:A1:FC
ESSID: unknown
Mode: Master Channel: 112
Encryption: none
Cell 11 - Address: D8:EC:5E:45:2A:81
Cell 12 - Address: A6:08:01:EA:8D:77
ESSID: unknown
Signal: -65 dBm Quality: 45/70
root@GL-SFT1200:~# uci -q get wireless.radio0.country
DE
root@GL-SFT1200:~# uci -q get wireless.radio1.country
DE
root@GL-SFT1200:~# cat /proc/gl-hw-info/country_code
DE
All looks about the same as on 4.3.25, but nothing showing in the Admin UI.
After that, I tried the radio setting stuff:
login as: root
OpenWrt 18.06, LEDE
root@GL-SFT1200:~# uci set wireless.radio0.country='GB'
root@GL-SFT1200:~# uci set wireless.radio1.country='GB'
root@GL-SFT1200:~# uci commit wireless
root@GL-SFT1200:~# wifi reload
ESSID: unknown
Signal: -54 dBm Quality: 56/70
ESSID: unknown
Encryption: none
ESSID: unknown
Cell 09 - Address: 60:8D:26:44:EF:24
ESSID: "BT-GTASZ8"
Signal: -72 dBm Quality: 38/70
Cell 10 - Address: 62:8D:26:44:EF:25
ESSID: "EE WiFi"
Encryption: none
ESSID: unknown
Cell 12 - Address: 80:75:1F:12:72:AA
ESSID: "SKYCQG2H"
Signal: -81 dBm Quality: 29/70
Cell 13 - Address: E4:75:DC:C3:23:83
ESSID: "BT-CHATZN"
Signal: -79 dBm Quality: 31/70
Cell 14 - Address: 40:A5:EF:B0:91:53
ESSID: "SKYNCBRM-2G"
Mode: Master Channel: 13
Cell 15 - Address: 54:B7:BD:AF:6A:D2
Cell 16 - Address: 7A:75:DC:C3:23:87
ESSID: unknown
Cell 17 - Address: 72:B7:BD:AF:6A:D6
ESSID: unknown
Cell 18 - Address: 90:02:18:C5:A7:96
ESSID: "SKYNCBRM"
Cell 19 - Address: 28:EC:9A:1A:C2:0D
ESSID: "podpoint"
Signal: -87 dBm Quality: 23/70
Encryption: none
HT Capabilities: UNKNOW
Cell 20 - Address: E8:48:B8:2D:26:5A
ESSID: "DecoDugHub"
Mode: Master Channel: 9
ESSID: "SKYCA5AC"
Signal: -61 dBm Quality: 49/70
ESSID: unknown
ESSID: "BT-GTASZ8"
ESSID: "EE WiFi"
Encryption: none
ESSID: "EE WiFi-X"
ESSID: unknown
Cell 08 - Address: A6:08:01:EA:8D:77
ESSID: unknown
Cell 10 - Address: D8:EC:5E:45:6F:91
Signal: -46 dBm Quality: 64/70
Signal: -49 dBm Quality: 61/70
Cell 12 - Address: FA:8F:CA:89:A1:FC
ESSID: unknown
Signal: -59 dBm Quality: 51/70
Encryption: none
GB
GB
DE
root@GL-SFT1200:~#
Obviously doesn’t affect the /proc/gl-hw-info/country_code.
Rescan on UI done (NOTE: as I’m a new user it will only let me put one media item in a comment
) so I can’t add more screenshots); showed “Wi-Fi is scanning; please wait a moment” then stops with no results. Now it doesn’t even say it can’t find any networks!
Rebooted the unit and tried again; same results.
Logs exported from the ui:
logread.tar.gz (27.1 KB)
Having had a quick look through you system.log, it looks to me like this is possibly your problem:
Tue Jun 9 11:10:06 2026 kern.warn kernel: [ 156.274073] lmac[1] use low txpower table
Tue Jun 9 11:10:07 2026 daemon.info gl-repeater[1145]: (repeater.lua:287) sta0: found 13 networks
Tue Jun 9 11:10:08 2026 daemon.err gl-repeater[1145]: (gl-repeater.lua:446) /usr/local/lib/lua/5.4/eco/nl80211.lua:648: bad argument #2 to 'unpack' (data string too short) stack traceback: [C]: in function 'string.unpack' /usr/local/lib/lua/5.4/eco/nl80211.lua:648: in upvalue 'parse_bss_ie' /usr/local/lib/lua/5.4/eco/nl80211.lua:716: in upvalue 'parse_bss' /usr/local/lib/lua/5.4/eco/nl80211.lua:823: in upvalue 'nl80211_scan' /usr/local/lib/lua/5.4/eco/nl80211.lua:856: in function 'eco.nl80211.scan' ./files/lib/repeater-nl80211.lua:584: in upvalue 'nl80211_get_scanresult' ./files/lib/repeater-nl80211.lua:821: in function 'gl.repeater-vendor.scan' ./files/lib/repeater.lua:265: in function <./files/lib/repeater.lua:260>
Tue Jun 9 11:10:10 2026 daemon.info gl-repeater[8680]: (gl-repeater.lua:457) lua-eco version: 3.16.0
Tue Jun 9 11:10:10 2026 daemon.info gl-repeater[8680]: (gl-repeater.lua:169) wait wifi config ready...
Tue Jun 9 11:10:10 2026 daemon.info gl-repeater[8680]: (gl-repeater.lua:149) radio0 wait wifi config ready...
Tue Jun 9 11:10:10 2026 daemon.info gl-repeater[8680]: (gl-repeater.lua:149) radio1 wait wifi config ready...
Tue Jun 9 11:10:10 2026 daemon.info gl-repeater[8680]: (gl-repeater.lua:194) load wifi config...
Tue Jun 9 11:10:11 2026 daemon.info gl-repeater[8680]: (gl-repeater.lua:216) found radio radio0
Tue Jun 9 11:10:11 2026 daemon.info gl-repeater[8680]: (gl-repeater.lua:216) found radio radio1
Tue Jun 9 11:10:11 2026 daemon.info gl-repeater[8680]: (gl-repeater.lua: 16) load repeater config...
Tue Jun 9 11:10:12 2026 daemon.info gl-repeater[8680]: (repeater.lua:1669) no saved network
Tue Jun 9 11:10:37 2026 daemon.info gl-repeater[8680]: (repeater.lua:429) scanning...
Tue Jun 9 11:10:37 2026 daemon.info gl-repeater[8680]: (repeater.lua:287) sta0: found 10 networks
Tue Jun 9 11:10:39 2026 daemon.err gl-repeater[8680]: (gl-repeater.lua:446) /usr/local/lib/lua/5.4/eco/nl80211.lua:648: bad argument #2 to 'unpack' (data string too short) stack traceback: [C]: in function 'string.unpack' /usr/local/lib/lua/5.4/eco/nl80211.lua:648: in upvalue 'parse_bss_ie' /usr/local/lib/lua/5.4/eco/nl80211.lua:716: in upvalue 'parse_bss' /usr/local/lib/lua/5.4/eco/nl80211.lua:823: in upvalue 'nl80211_scan' /usr/local/lib/lua/5.4/eco/nl80211.lua:856: in function 'eco.nl80211.scan' ./files/lib/repeater-nl80211.lua:584: in upvalue 'nl80211_get_scanresult' ./files/lib/repeater-nl80211.lua:821: in function 'gl.repeater-vendor.scan' ./files/lib/repeater.lua:265: in function <./files/lib/repeater.lua:260>
Tue Jun 9 11:10:41 2026 daemon.info gl-repeater[9094]: (gl-repeater.lua:457) lua-eco version: 3.16.0
Tue Jun 9 11:10:41 2026 daemon.info gl-repeater[9094]: (gl-repeater.lua:169) wait wifi config ready...
Tue Jun 9 11:10:41 2026 daemon.info gl-repeater[9094]: (gl-repeater.lua:149) radio0 wait wifi config ready...
Tue Jun 9 11:10:41 2026 daemon.info gl-repeater[9094]: (gl-repeater.lua:149) radio1 wait wifi config ready...
Passing bad data to a lua script that’s presumably, the link between the scan and the UI.
I’m done; returning to Amazon.
HTH
