Shadosocks library error libsodium.so.18
shadowsocks not work , error with library can’t load libsodium.so.18
this is happen with new one i bought . i still have 2 gl-mt300n and they work good.
i do not know what is changed whit this new one . this is colored Yellow . before black .
because i need use in china shadowsocks is for me important.
please help me
The yellow one should be MT300N or MT300N-V2 while the black one is AR300M.
There is a bug in the yellow one and you cannot load libsodium.so.18, but you can find libsodium.so.X in /usr/lib and you can just make a symbol link
X is some number that I cannot remember.
ln -s /usr/lib/libsodium.so.X /usr/lib/libsodium.so.18
yes different model , now work with link to library
thank for help
