Hello! I'd like to share my solution for setting up Shadowsocks with the hardware switch, similar to how TOR, WireGuard, and OpenVPN are handled.
!!! This guide involves modifying system files. Your configuration may be lost after a firmware update. Proceed at your own risk — I take no responsibility for bricked devices, even though the changes are minor.
I’m using the GL-E750 (4G LTE) router.
Firmware version: 4.0
Kernel version: 5.10.176
OpenWRT version: 22.03.4
Required packages
Run:
opkg update
opkg install \
luci-app-shadowsocks-libev \
shadowsocks-libev-ss-redir \
shadowsocks-libev-config
UCI configuration for Shadowsocks server and ss-redir instance
SERVER_NAME='Bulgaria'
SERVER_ADDRESS='1.1.1.1'
SERVER_PORT=38583
SERVER_PROTO='chacha20-ietf-poly1305'
SERVER_PASS='YoUr_pASS'
LOCAL_PORT=12345
uci set shadowsocks-libev.$SERVER_NAME=server
uci set shadowsocks-libev.$SERVER_NAME.server="$SERVER_ADDRESS"
uci set shadowsocks-libev.$SERVER_NAME.server_port="$SERVER_PORT"
uci set shadowsocks-libev.$SERVER_NAME.method="$SERVER_PROTO"
uci set shadowsocks-libev.$SERVER_NAME.password="$SERVER_PASS"
uci set shadowsocks-libev.VPN_redir=ss_redir
uci set shadowsocks-libev.VPN_redir.disabled='0'
uci set shadowsocks-libev.VPN_redir.mode='tcp_and_udp'
uci set shadowsocks-libev.VPN_redir.fast_open='1'
uci set shadowsocks-libev.VPN_redir.no_delay='1'
uci set shadowsocks-libev.VPN_redir.reuse_port='1'
uci set shadowsocks-libev.VPN_redir.server="$SERVER_NAME"
uci set shadowsocks-libev.VPN_redir.local_port="$LOCAL_PORT"
# Enable Shadowsocks option for hardware switch
uci set switch-button.@main[0].func='shadowsocks'
uci commit
Create /etc/gl-switch.d/shadowsocks.sh
that will be executed on switch turn on\off.
#!/bin/sh
action=$1
port=12345
chain=SHADOWSOCKS
if [ "$action" = "on" ]; then
# Start ss-redir service
/etc/init.d/shadowsocks-libev start
# Add iptables rules
iptables -t nat -N $chain 2>/dev/null
iptables -t nat -F $chain
iptables -t nat -A $chain -d 192.168.0.0/16 -j RETURN
iptables -t nat -A $chain -p tcp -j REDIRECT --to-ports $port
iptables -t nat -A PREROUTING -i br-lan -p tcp -j $chain
# Drop existing connections
conntrack -F
else
# Delete iptables rules
iptables -t nat -D PREROUTING -i br-lan -p tcp -j $chain
iptables -t nat -X $chain
# Stop ss-redir service
/etc/init.d/shadowsocks-libev stop
fi
Then make it executable:
chmod +x /etc/gl-switch.d/shadowsocks.sh
Now you can toggle Shadowsocks VPN using the router's hardware switch.
You can also manually start/stop the VPN using:
/etc/gl-switch.d/shadowsocks.sh on
/etc/gl-switch.d/shadowsocks.sh off
Hope this helps someone!
