Share folder not on USB
I have create a folder and mount remonte file, i need to share it using NAS on Flint2.
If i add it from luci, after restart i lost my custom sharing
I believe this issue may be related to the requirements mentioned in your other post.
Please try following the solution outlined there first.
However, if this issue is unrelated, please provide the following details so we can investigate further:
  1. Firmware version
  2. Specific configurations that were added or modified in Luci
I’m using last version 4.8.3-op24 (OpenWrt 24.10.4 r28959-29397011cc),
I add configuration using a custom script
uci add samba4 sambashare
    uci set samba4.@sambashare\[-1\].name="r1d"          # Share name
    uci set samba4.@sambashare\[-1\].path="$base_mount_dir"
    uci set samba4.@sambashare\[-1\].guest_ok='yes'
    uci set samba4.@sambashare\[-1\].read_only='yes'      # Read-only
    uci commit samba4
the script work fine,
but after some time the config is lost on samba, like gl_nas restore configuration only for USB
Yes, as I mentioned in your other thread.
When there are configuration changes in Application - Network Storage, it will overwrite the samba4 configuration, including any parts set/modified via uci.
If you wish to use uci to configure features not currently available in the GL UI, we recommend you disable Application - Network Storage and only use uci to configure samba4 and /etc/init.d/samba4 to manage its startup.
