Hello Guys
How to share files via Lan?
Thank you.
Hello Guys
Thank you.
Hello.
In main Web Admin go to Applications> File sharing. Install it if not installed. Internet required. (That installs Samba2 on your router).
You must put the place where your SD or USB device is located in the small window and allow whatever you want in Options for example Sharing from WAN, only LAN and Write permissions to the SD or USB device. I don’t have it installed, so I can’t take pictures now. I have installed Samba4 which has more options but it is configured from Luci.
Then in your computer or device you must look after the Shared Folder in 192.168.8.1 (if you keep the default router IP)
Bye
