Hello!
I wonder why GL-X1200 / Amarok
GL-X1200 / Amarok
is 867Mbps/5Ghz
and Slate
GL-AR750S / Slate
is 433Mbps/5Ghz.
They have the same QCA9563, @775MHz SoC CPU. Same RAM also but ok RAM not responsible of speed.
Thank you.
Bye!
Hello!
GL-X1200 / Amarok
is 867Mbps/5Ghz
and Slate
GL-AR750S / Slate
is 433Mbps/5Ghz.
Thank you.
Bye!
The radio, needs separate chipset and hardware design.
So it is not related to CPU or RAM.
For example, you can design a product using the same chipset but no wifi at all.
