SIM activation without phone
For routers that take the SIMcard how would I activate the card without a phone?
If the SIM card needs to be activated operation, it actually needs to be operated by the phone.
The router cannot be simulated or work as a phone to be activate the SIM card.
Depends on the provider. (Who)
Sometimes their shop might do it for you on demo phone.
Might not need it if you configure router settings.
Ok will an adapter for a mirco SIM card work wasn’t aware of that
So I get connected but nothing plays keeps saying check connection then it disconnected and now says no internet
  1. Please check the modem status and SIM status using following AT commands in Admin Panel > Internet > Modem > ··· > Modem AT command:
AT+CFUN?
AT+CSQ
AT+COPS?
  1. Please export modem-debug info from Admin Panel > Internet > Modem > ··· > Modem AT command:
  2. Please export the system log (logread.tar) from Admin Panel > SYSTEM > Log
  3. Your use region and SIM card operator
  4. Please share the above results through PM me or email [email protected], our cellular technical expert will take care this question.
