Is it possible to make it work on e750?
When plugged in, all lights are working, but dmesg says
error -32
on all actions to connect to it and finally says:
usb 1-1-port3: unable to enumerate USB device
error -32
You need to get the drivers. It could be difficult.
Some thread for your reference [SOLVED] LTE QMI Troubles - Installing and Using OpenWrt - OpenWrt Forum
