(I’ve googled and it looks complicated… perhaps there is an easy way using the Luci Gui? If not, so be it.
I believe I’m at release 2.27… Please fix that for a subsequent release.)
I have the AR300M-lite. I want to connect an OBIhai telephone adapter to it via the Ethernet port and then WiFi to my house WiFi/router system. Ideally this should just be a few clicks from the out-of-the-box AR300M configuration, which assumes the Ethernet will go to a WAN service like a cable modem.
So what’s the easiest way to accomplish this? It’s okay if the Ethernet ends appears as a LAN client (bridged) on the same subnet with my other wifi devices… Or if the AR300M puts another layer of routing as it does out-of-the-box with its own WiFi clients.
If it ain’t easy, then lay it all out for us… I can hack configuration files, iptables, and so on if that’s what it takes… But as this is not such an exotic request perhaps I’m just not seeing the clicks I need in Luci – I’ve tried a few times to just point and shoot my way through the “advanced” Luci/GUI – no luck - so here I am…
