SIMPoYo 5G uFi
When will the SIMPoYo 5G uFi be released to the public? ( SIMPoYo 5G uFi: Plug & Play 5G Global High-speed USB Dongle - GL.iNet ),
And will it be compatible with Beryl AX’s 3.0 usb port for 5G internet?
Thank you,
Currently, the SIMPoYO 5G uFi is still in the early stages of product development, so there is not much information available to share yet.
Regarding the MT3000, due to limitations in its USB power output, it may require a USB Y-cable to properly power the 5G uFi.
Thank you Will
And with the beryl 7 ?
I think Beryl 7 should be able to power the SIMPoYO 5G uFi directly without issue.
But as previously mentioned, we do not have much information available at this time.
Please do not worry; we will test its compatibility with our existing products and provide a solution accordingly.
I already have Beryl 7 and I have applied to be a beta Tester. I hope I get selected as I am in a position to tess all 3 5G Networks of India.
Thank you for your interest in and support of GL.iNet products.
The testing participant list for the SIMPoYo 5G uFi has not yet been finalized—please stay tuned for further updates.
