SIMPoYo eSIM
got a mail from GL about this physical e-sim card.
pls verify that i can buy surf from airalo and use with this card
most important, can i use the card in a router which does not support esim (d-link dwr-2101) if i use my android phone to buy surf and then put the card in my router?
Hello, the Airalo esim can be used with the SIMPoYo eSIM card.
SIMPoYo eSIM works with other routers. You may need to enable the eSIM profile on your Android phone if the router lacks eSIM management tool.
When usb modem SIMPoyo will be available for sale?
SIMPoYo uFi is expected to be launched by the end of this month. You can subscribe here to get the latest updates.
