please need help for Site to Site connection.
First I tried with Wireguard client/server configuration, the connection was established, I can ping the client/server ips each others, but no way to ping the devices on the lan each others. I added the string “list subnet ‘192.168.1.0/24’” to the server config but it did not work. Then I tried with Goodcloud, but I got the same problem, the connection between the routers seems ok:
“Allow be Access for the Following Subnets” is correctly checked (created automatically) for the two subnets, but again the lans behind routers cannot ping each others.
I too am having this same issue. While utilizing GoodCloud I cannot ping from devices behind nodes to devices behind nodes. I am also wondering if the 2 networks behind the nodes can be the same subnet?
Hello I have my site too site with your device , I used good Cloud to make it ,
my customer ask for use wireguard app for enter in the site to site network (in the aggregate node) ,
How can i create a peer in the main node in wg1 for the wireguard app ?
I try to open a second wg server and in this case I can connect with the app wireguard without issue and I reach the LAN network, BUT I cannot be routed with the others connected networks s2s .
Could be a firewall rule that block it ?
In any case thank you very much for your support …
