Hi all, My slate 7 is connected to my flint 2 as an extender, which works great. unfortunately when i connect to my flint 2 i cannot see the devices o the slate. Flint is 192.168.1.1 and slate is 192.168.80.1. anyone know how to route traffic between them? ta
It's been a while but IIRC wireless bridges/aka 'extenders' are required to be on the same subnet. What you're describing is a 'repeater'.
Yes, you are correct. Any solutions?
May we know now which network mode that Slate 7 running?
If it is the 'router mode' and you are using the Wi-Fi repeater connect the Slate 7 to Flint 2.
Maybe you can refer to this discussion to set up the routing and firewall for your purpose.
