Slate AX GL-AXT1800 Wiregurad VPN connection
I have just bought this router and trying to connect Wireguard VPN. I am getting following error, if you could please help me solve it.
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): * Zone ‘wan’
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): * Zone ‘guest’
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): * Zone ‘wgclient’
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): * Zone ‘wgserver’
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): * Set tcp_ecn to off
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): * Set tcp_syncookies to on
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): * Set tcp_window_scaling to on
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): * Running script ‘/etc/firewall.nat6’
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): * Running script ‘/etc/firewall.vpn_server_policy.sh’
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): iptables v1.8.7 (legacy): unknown option “–save-mark”
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): Try `iptables -h’ or ‘iptables --help’ for more information.
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): * Running script ‘/etc/firewall.swap_wan_in_conn_mark.sh’
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): * Running script ‘/var/etc/gls2s.include’
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): ! Skipping due to path error: No such file or directory
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): * Running script ‘/usr/bin/gl_block.sh’
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): uci: Entry not found
Mon Feb 5 15:41:09 2024 daemon.notice netifd: wgclient (18751): cat: can’t open ‘/tmp/run/wg_resolved_ip’: No such file or directory
Mon Feb 5 15:41:09 2024 daemon.notice netifd: Interface ‘wgclient’ is now down
Mon Feb 5 15:41:09 2024 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Mon Feb 5 15:41:09 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
The log does not show the reason.
What is your Wireguard server?
Hi Alzhao,
I went to Wiregaurd server portion on left side pane and clicked profiles, created a profile, downloaded the configuration and then uploaded the same configuration in Wireguard client.
Thanks.
You cannot use one router as server and then connect to it as client using the same router.
You need to have a vpn server
oh okay thanks. I want to use this as hardware VPN. So I can connect to builtin Wireguard VPN and access websites which are not supported in our region. Have I chosen a wrong Product then?
You need an wireguard service provider for that.
Like www.mullvad.net
That is so confusing, then why is there Wireguard and OpenVPN server option? Can I make my router wireguard vpn server and connect my mobile as client to use the VPN?
Exactly that’s the reason.
Ok thanks for help, really appreciated. Hope this device works.
