Slate AX LED flashes
My slate AX LED flashes and I cannot access to internet, reset it for several times and still not working. What can I do?
I have the .tar file before I reset it, will it be useful?
My local network setup is as below:
https://forum.gl-inet.com/t/slate-ax-and-opal-network-problems/39024
The flashing LED means that you do not have “internet” connection
Are you able to connect to the Slate’s Admin console/UI ? and then check the status ?
Most likely you are not connected to any WiFi.
