If I insert an SD card in the running router it gets mounted ok:
/dev/mmcblk0p1: UUID=“c70f0b78-bfe6-468e-8bc7-6e5364fc15af” BLOCK_SIZE=“4096” TYPE=“ext4”
/dev/mmcblk0p1 7747568 70704 7261812 1% /tmp/mountd/disk3_part1
However I can not find any trace of it after a reboot, no entry in output from blkid
I use the SD card for automatic backups so I hope you will fix this.
firmware 2022-06-28 7:21:42(UTC+08:00)
alzhao
July 8, 2022, 10:17am
2
So you mean after reboot, the SD card is not mounted.
But if the router is on already and you plug it in, it works OK. right?
alzhao
July 8, 2022, 10:56am
4
@dengxinfa can you have a check.
alzhao
July 14, 2022, 8:30am
5
The problem is fixed and will release test firmware tomorrow.
jdub
July 14, 2022, 10:36am
6
Is there a way to disable this? Auto mounting is not desired behavior for those of us who use encrypted file systems on the microSD slot. It would be better to have something edit /etc/fstab so people who want the card to auto-mount can do so, rather than forcing the card to auto mount by default.
alzhao
July 14, 2022, 10:49am
7
Yes, remove the mount script in /etc/hotplug.d/block
jdub
July 14, 2022, 11:54am
8
I assume we’ll have to do this after every firmware update?
can confirm it works in beta2
