# Slate AX + Slate AX VPN Issue
**URL:** <https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353>\
**Category:** VPN, DNS, Leaks\
**Created:** [November 20, 2023, 10:23pm UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353 "2023-11-20T22:23:33Z")\
**Posts on this page:** 15\
**Page:** 1
<div class="post-metadata">
**Author:** ![soudy2](https://forum-assets.gl-inet.com/letter_avatar_proxy/v4/letter/s/6de8d8/32.png) [@soudy2](https://forum.gl-inet.com/u/soudy2)\
**Post date:** [November 20, 2023, 10:23pm UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353/1 "2023-11-20T22:23:33Z")
</div>
Im trying to setup a Wireguard Server and Wireguard Client.
**2x Slate AX** ( GL-AXT-1800) ( Also, have Brume 2 & Mango if needed).
**Existing home router:** ( TP-Link Archer AX1800 or it can be a Netgear AC1750 R6350).
**ISP** : Fiber
I already attempted to configure both using a ton of previous threads/walk throughs.
I think I am getting snagged at the port forwarding on the home router or im getting confused on the IP config between the Slate AX’s maybe causing conflict?
Server gets established and green but unable to connect via phone or travel Ax/PC.
**Goal:** Keep one Slate AX at the house, the other Slate AX comes with me when I travel.
**Home Router:**
- Dynamic IP from ISP
- Port Forward: 51820
- Port Forward on TCP/UDP then just only UDP.
- Ethernet from LAN going to the WAN Port of Slate AX Server.
- Static IP assigned for Slate AX Server w/ port forward.
**Slate AX Server:**
Default: 10.0.42.1/24
Local Port: 51820(current)
DDNS enabled
v4.4.6
[http://192.168.8.1/](http://192.168.8.1/)
No port forwarding configured on server, just on home router port forwarding the static IP of Slate AX Server w/ 58120 port udp only
**Global Options:**
- VPN Cascading : enabled
- Block non-VPN Traffic: ?
- Allow Access WAN: prob wont need
- Services from GL.iNet Use VPN: ?
----- AX Client Config Below----
**Slate AX Client:**
[http://192.168.5.1/](http://192.168.5.1/)
v4.4.6
**Global Options:**
Block Non-VPN traffic : ?
Allow Access WAN : ? prob not needed?
Services from GL iNet use VPN: ?
**Questions:**
- The Kill switch is configured in global options in server or client ax?
- IP Masqeradin on which Slate? Client or Server?
- Port : 51820, i heard can be throttled from ISP? is there another lowkey one thats preferred?
- MTU : Tried adjusting down to 1280, 1300, does this need to match server/client MTU?
**Author:** ![bring.fringe18](https://forum-assets.gl-inet.com/user_avatar/forum.gl-inet.com/bring.fringe18/32/11777_2.png) [@bring.fringe18](https://forum.gl-inet.com/u/bring.fringe18)\
**Post date:** [November 20, 2023, 10:39pm UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353/2 "2023-11-20T22:39:47Z")
</div>
SSH into whatever device is to act as the Server (see below for links). Check the WG port is open on the public IP/WAN/Internet side:
- `opkg update; opkg install nmap curl`
- `curl http://ipecho.net/plain; echo` or visit [ipleak.net](http://ipleak.net)
- `nmap $publicIPHere -sU -p 51820 `
> [@HOW-TO: Script: List My OPKGs (to a file for backup)](https://forum.gl-inet.com/t/how-to-script-list-my-opkgs-to-a-file-for-backup/30963/3):
> References & Resources
> **[IP/DNS Detect](https://ipleak.net)**
> What is your IP, what is your DNS, check your torrent IP, what informations you send to websites.
**Post date:** [November 22, 2023, 8:53pm UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353/3 "2023-11-22T20:53:16Z")
</div>
Hey quick update
I had to call my isp to place my IP outside of the NAT.
Which allowed the port forwarding to work.
I am now able to establish a connection but the speed is very slow, 5kb up/down
I am testing on a Mint/Tmobile hotspot connection and tested a few different MTU settings.
MTU
S: 1280 C:1280 156b/28kb
S: 1300 C:1300 6kb down/1mb up
S: 1320 C:1320 1kb down / 158kb up
S: 1340 C:1340 2kb down/ 244kb up
S: 1360 C:1360 156b/26kb
S: 1380 C:1380 312b/21kb
S: 1400 C:1400 188b/37kb
S: 1420 C:1420 380b/86kb
S: 1440 C:1440 1kb/170kb
S: 1460 C:1460 760b/104kb
S: 1480 C:1480 284b/31kb
S: 1500 C:1500 252b/38kb
I will be testing from another residental wifi network later today but im curious about these settings below
**Slate AX Server**
Global Options
- VPN Cascading: yes or no?
**Wireguard Options**
- Allow Remote LAN : probably N
- IP Masquerading: yes or no?
- MTU : Testing diff ones
**Slate Client**
Global Proxy or Auto Detect?
**Global Options**
- Block Non VPN Traffic: will eventually be yes
- Allow WAN: prob gonna be no
- Services from Gli use VPN: ??
**WG Client Options**
- Allow Remote Access LAN : prob gonna be No?
- IP Masquerading: ?
- MTU : still kinda testing
Any insight on what those settings need to be?
**Post date:** [November 24, 2023, 11:01am UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353/4 "2023-11-24T11:01:23Z")
</div>
On my WG Server I have IP Masquerading on. VPN Cascading wouldn’t apply unless your WG Server device was itself to be a WG Client to a VPN provider (eg: Mullvad, Nord VPN, Express VPN, etc.).
“Services fr GL” refers to such processes like their DDNS service. My WG Client has IP Masquerading on.
**Post date:** [November 25, 2023, 2:03am UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353/5 "2023-11-25T02:03:06Z")
</div>
Thank you for that info but im still only getting 150b/3kb up/down.
It shows a green connection but I dont have internet when connecting to the Server Slate.
I am testing from a tmobile/mint cell hotspot to test (& Local coffee shop), I read the lower MTU works on this mint/tmobile carrier better, but tested alot of variations with no change on the speeds.
Since the up/down is virtually non-existent, it seems its still a bad config issue i think.
I recently just changed my Slate Server IPv4 IP to 10.20.0.1. Instead of the 10.0.0.1 and produced new WG profiles and just been tweaking MTU. ( also mocked the above config in regard to IP masq., server vpn cascading etc.
Also, do I need to setup port forward **on** my Slate AX Server ? Currently I just have port forward on my ISP TP-Link Router–\> Slate AX Server but not → Slate AX Client
is there any other config needed **on** the Slate AX Server itself? Not WG configs and not DDNS(its already enabled).
Is there like a config export I can send to export all my config settings? not sure what the next area to check is.
Thanks!
Also note, when scanning my WAN IP, it says port: open|filtered.
Ive been reading that means it didnt get a response.
any commands i can ssh to get to the bottom of this? plz let me know which commands need to be on the ISP router, Slate AX Server or Slate AX Client. ( also let me know if i should be doing these commands while ON the WireGuard?)
**Author:** ![alzhao](https://forum-assets.gl-inet.com/letter_avatar_proxy/v4/letter/a/5f9b8f/32.png) [@alzhao](https://forum.gl-inet.com/u/alzhao)\
**Post date:** [November 25, 2023, 8:29am UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353/6 "2023-11-25T08:29:29Z")
</div>
Your settings are fine. Don’t need to do more in ports forward and vpn options.
Make sure IP Masquerading is on which should be the default value.
Here is more steps to check.
1. Try other ports other than 51820. Maybe not making any difference.
2. Try mtu 1280 on both server and client. Not only in one side.
3. Try OpenVPN which use TCP. Not sure if Wireguard udp is throttled.
4. The use the config directly on phone. This will know if the problem is only server side or both side.
**Post date:** [November 25, 2023, 8:48pm UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353/7 "2023-11-25T20:48:34Z")
</div>
Thank you,
I adjusted the MTU to 1280 on both server and client.
I will adjust the port fwd to another port and try that later today.
I was able to connect on my phone via the WG app and on cell network but I was not able to load any sites or anything. It said 1 device connected on the WG Server dash but the speeds were only 500 bytes down and 20kb up and nothing loaded.
The home network of the ISP router and both slates is a fiber connection and gets 600MB down/up consistently.
Im going to try the local coffee shop again shortly and put the MTUs on both Server/client back to default, which i think is like 1400.
what else should i be doing to try to narrow down what this issue is related to?
**Post date:** [November 25, 2023, 10:21pm UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353/8 "2023-11-25T22:21:48Z")
</div>
To find the best MTU increase fr 1280 incrementing by 10. Max is 1420. Don’t forget to disc/reconnect between changes.
**Post date:** [November 27, 2023, 4:49am UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353/9 "2023-11-27T04:49:25Z")
</div>
You haven’t try the openvpn in tcp protocol. Can you try?
**Post date:** [November 27, 2023, 3:06pm UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353/10 "2023-11-27T15:06:21Z")
</div>
hey team,
So instead of using the TP-Link Router as the ISP router.
I completely removed the TP-link router from the network.
The Slate AX Server is now directly plugged into the wall, which I will use the 5ghz wifi as the home network wifi and run the VPN server as well.
Let me know if this setup may cause any leaks in my VPN IP etc.\
OpenVPN works when I connect and transfers around 20mb down/ 20 mb up - which is alright but the home speeds are around 900MB down and 900MB up. So hopefully can still get the WG VPN to work.
I will continue to test later today on the WG setup without the TP link router.
If the TCP OpenVPN setup works but the UDP Wireguard setup does not, does this point to something specific blocking WG?
Thanks
**Post date:** [November 28, 2023, 1:42am UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353/11 "2023-11-28T01:42:10Z")
</div>
Since my Slate server is directly into the wall and not using my old TP-link as the main router which had the port forwarding.
when port forwarding on the slate ax, what do i set these fields to?
Protocol: UDP
**External Zone :** LAN, WAN, guest, wgserver, ovpnserver ?
External Port: 51820
**Internal Zone:** LAN, WAN, guest, wgserver, ovpnserver ?
Internal Port: 51820
Should I only do UDP? or should I add another separate one for just TCP?
Thanks!
**Post date:** [November 29, 2023, 12:40am UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353/12 "2023-11-29T00:40:54Z")
</div>
WG is UDP only.
If you’re using the GL GUI → VPN → WireGuard Server to set things up, all port forwarding is handled for your ‘behind the scenes’.
You should check to make sure your ISP/Public IP/Internet IP allows incoming connections to port 51820… otherwise you’ll never reach the Slate AX WG Server.
> **[WireGuard Server - GL.iNet Router Docs 4](https://docs.gl-inet.com/router/en/4/interface_guide/wireguard_server/)**
> Documentation for GL.iNet Router Productions
**Post date:** [November 29, 2023, 4:59am UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353/13 "2023-11-29T04:59:38Z")
</div>
As Slate AX is the main router, to work as vpn server, you do NOT need to set up any porforward on it.
Enabling vpn server is sufficient enough.
**Post date:** [November 29, 2023, 10:28pm UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353/14 "2023-11-29T22:28:17Z")
</div>
Hopefully OP isn’t behind CGNAT. @soudy2, you may need to contact your ISP to find out. Their ‘front facing’ routers could be blocking incoming connections to you Public IP.
> **[Carrier-grade NAT](https://en.wikipedia.org/wiki/Carrier-grade_NAT)**
> Carrier-grade NAT (CGN or CGNAT), also known as large-scale NAT (LSN), is a type of network address translation (NAT) used by ISPs in IPv4 network design. With CGNAT, end sites, in particular residential networks, are configured with private network addresses that are translated to public IPv4 addresses by middlebox network address translator devices embedded in the network operator's network, permitting the sharing of small pools of public addresses among many end users. This essentially repeats...
**Author:** ![bruce](https://forum-assets.gl-inet.com/user_avatar/forum.gl-inet.com/bruce/32/35649_2.png) [@bruce](https://forum.gl-inet.com/u/bruce)\
**Post date:** [October 29, 2025, 4:27am UTC](https://forum.gl-inet.com/t/slate-ax-slate-ax-vpn-issue/35353/15 "2025-10-29T04:27:35Z")
</div>
