Slate AX USB 3.0 cold boot Issue - 4.4.6-0908
Have to:
rmmod dwc3
modprobe dwc3
in rc.local to switch USB speed from 1.1 to 3.0 (5Gbps)
Using UASP capable external HDD.
Edit: irrelevant logs.
UAS is supported OOTB:
root@flint:~# logread -e uas
Sun Nov 12 01:07:33 2023 kern.alert kernel: [    1.280548] mtdsplit: no squashfs found in "rootfs"
Sun Nov 12 01:07:33 2023 kern.info kernel: [    2.670012] VFS: Mounted root (squashfs filesystem) readonly on device 31:12.
Sun Nov 12 01:07:33 2023 kern.info kernel: [    4.558114] usbcore: registered new interface driver uas
root@flint:~# logread -e xhci
Sun Nov 12 01:07:33 2023 kern.info kernel: [    4.494016] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Sun Nov 12 01:07:33 2023 kern.info kernel: [    4.494057] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
Sun Nov 12 01:07:33 2023 kern.info kernel: [    4.499361] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe65 hci version 0x110 quirks 0x00010010
Sun Nov 12 01:07:33 2023 kern.info kernel: [    4.505990] xhci-hcd xhci-hcd.0.auto: irq 186, io mem 0x08a00000
Sun Nov 12 01:07:33 2023 kern.info kernel: [    4.524673] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Sun Nov 12 01:07:33 2023 kern.info kernel: [    4.528518] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
Sun Nov 12 01:07:33 2023 kern.info kernel: [    4.964544] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
root@flint:~# logread -e usb
Sun Nov 12 01:07:33 2023 kern.info kernel: [    4.180080] usbcore: registered new interface driver usbfs
Sun Nov 12 01:07:33 2023 kern.info kernel: [    4.180145] usbcore: registered new interface driver hub
Sun Nov 12 01:07:33 2023 kern.info kernel: [    4.184570] usbcore: registered new device driver usb
Sun Nov 12 01:07:33 2023 kern.err kernel: [    4.230951] ipq6018-pinctrl 1000000.pinctrl: pin GPIO_0 already requested by soc:gpio-export; cannot claim for 8af8800.usb3
Sun Nov 12 01:07:33 2023 kern.err kernel: [    4.236210] ipq6018-pinctrl 1000000.pinctrl: pin-0 (8af8800.usb3) status -22
Sun Nov 12 01:07:33 2023 kern.err kernel: [    4.254299] dwc3-qcom 8af8800.usb3: Error applying setting, reverse things back
Sun Nov 12 01:07:33 2023 kern.info kernel: [    4.268263] msm-usb-ssphy-qmp 78000.ssphy: Initializing QMP phy
Sun Nov 12 01:07:33 2023 kern.err kernel: [    4.281556] msm-usb-ssphy-qmp 78000.ssphy: QMP PHY initialization timeout
Sun Nov 12 01:07:33 2023 kern.err kernel: [    4.281580] msm-usb-ssphy-qmp 78000.ssphy: USB3_PHY_PCS_STATUS:68686868
Sun Nov 12 01:07:33 2023 kern.info kernel: [    4.533849] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Sun Nov 12 01:07:33 2023 kern.info kernel: [    4.555336] usbcore: registered new interface driver usb-storage
Sun Nov 12 01:07:33 2023 kern.info kernel: [    5.002316] usb-storage 2-1:1.0: USB Mass Storage device detected
Sun Nov 12 01:07:33 2023 kern.info kernel: [    5.002553] scsi host0: usb-storage 2-1:1.0
Sun Nov 12 01:07:33 2023 kern.info kernel: [   14.744383] usbcore: registered new interface driver cdc_acm
Sun Nov 12 01:07:33 2023 kern.info kernel: [   14.752594] usbcore: registered new interface driver cdc_wdm
Sun Nov 12 01:07:33 2023 kern.info kernel: [   14.794571] usbcore: registered new interface driver ipheth
Sun Nov 12 01:07:33 2023 kern.info kernel: [   14.945769] usbcore: registered new interface driver usbserial
Sun Nov 12 01:07:33 2023 kern.info kernel: [   14.945858] usbcore: registered new interface driver usbserial_generic
Sun Nov 12 01:07:33 2023 kern.info kernel: [   14.950583] usbserial: USB Serial support registered for generic
Sun Nov 12 01:07:33 2023 kern.info kernel: [   14.996783] usbcore: registered new interface driver cdc_ether
Sun Nov 12 01:07:33 2023 kern.info kernel: [   15.000912] usbcore: registered new interface driver cdc_ncm
Sun Nov 12 01:07:33 2023 kern.info kernel: [   15.064255] usbcore: registered new interface driver huawei_cdc_ncm
Sun Nov 12 01:07:33 2023 kern.info kernel: [   15.220339] usbcore: registered new interface driver qmi_wwan
Sun Nov 12 01:07:33 2023 kern.info kernel: [   15.224837] usbcore: registered new interface driver rndis_host
Sun Nov 12 01:07:33 2023 kern.info kernel: [   15.388009] usbcore: registered new interface driver option
Sun Nov 12 01:07:33 2023 kern.info kernel: [   15.388079] usbserial: USB Serial support registered for GSM modem (1-port)
Sun Nov 12 01:08:31 2023 daemon.err usbmuxd[9267]: [01:08:31.642][3] usbmuxd v1.1.1 starting up
Sun Nov 12 01:08:31 2023 daemon.err usbmuxd[9267]: [01:08:31.642][3] Using libusb 1.0.22
Sun Nov 12 01:08:31 2023 daemon.err usbmuxd[9267]: [01:08:31.643][3] Initialization complete
Sun Nov 12 01:08:31 2023 daemon.err usbmuxd[9267]: [01:08:31.643][3] Enabled exit on SIGUSR1 if no devices are attached. Start a new instance with "--exit" to trigger.
Flint v1, f/w 4.4.6-release1
hdparm -t /dev/sda when booting with the USB plugged in is 6MB/s, 450MB/s after replugging or reloading dwc3. (megabytes)
What is dwc3? I don’t have that process on my Flint.
root@flint:~# hdparm -t /dev/sda
/dev/sda:
 Timing buffered disk reads:  54 MB in  3.09 seconds =  17.49 MB/sec
root@flint:~# uptime
 05:44:59 up 23:43,  load average: 0.21, 0.15, 0.10
@bring.fringe18 At the risk of being offtopic since moderation isn’t active here, why are you replying to every post on this forum while partially reading the details, and having completely irrelevant replies, not to mention calling users with glinet staff tag names (weebs etc)?
In my post I mentioned modprobe, that’s for loading kernel module, not process.
I never mentioned that it didn’t support UAS, maybe you are using a translator?
Although Flint & SlateAX are very similar they do have slightly different build config and pin mappings.
I really appreciate your efforts on being helpful, but there is no need to needlessly reply to every post with irrelevant details as it may deter helpful responses.
Thanks for your time, need to recompile kernel with debug flags to logwalk, for now I’m simply reloading the module as a dirty fix.
You may have missed it but the logs you provided show dwc3.
You were rude to few people here hence my honest reply, flagging didn’t do much, I hope this public complaint grabs attention, not sure what’s the point of sabotaging/spamming a technical forum…
You’re more than welcome to look over my post history. Be sure to note how many ‘Solutions’ you have.
JFC.
ps/ My Slate AX is a backup unit but thanks for reminding me it needs some TLC. At least you can say you’re good for something.
