I upgraded my slate some time ago to openwrt 21.02, the primary reason was to be able to
connect to 5G DFS channels which the GL firmware did not support.
Everything works except for 5G Access point mode which works briefly and then the signal disappears.
- Is this a known problem with Openwrt 21.02?
- Does AP mode work correctly for both 2.4 and 5G if I use GL firmware? I assume yes, but just checking…
- If I use GL firmware, can I connect to DFS channels by using Luci like on standard Openwrt?
- Interested in the upcoming Slate AX, will there be any difference with regard to DFS channel support?
Many thanks for advice
