Hello i reset my slate plus and when i was configuring it it showed this message when i click next after typing the password for the admin account could someone help me pls do i need to uboot or else
Hi there,
I can't reproduce your problem locally.
Please ensure your device is still connected to the router via wired or wireless connection.
We recommend that you wait for 10 minutes before restarting the device. Then try accessing the admin page.
If this doesn't work, you can upgrade the router's firmware via Uboot and test again.
ok i am gonna try
thank you it worked but now i have beta version no probleme little question how do i change my mac adress of the slate if i need to connect in hotel wifi.
When selecting the WiFi to connect to, change the MAC address mode to clone, and then manually enter the address you need.
You can also directly turn on camouflage mode, If this option is enabled, this router camouflage itself as the same device as the client device you are now using.
