Slate Plus (GL-A1300) WG VPN connection freezes every 10 minutes
Nope. That didn’t seem to help.
I’ve bumped the Track Interval from: 10 seconds to 30 seconds.
I’ve bumped the Change to Failure Condition from: Ping failures 5 times to 8 times.
No change.
I’ve run the following:
root@GL-A1300:~# logread -e mwan3
Mon Nov 20 09:50:09 2023 user.notice mwan3[6304]: Execute ifup event on interface wgclient (wgclient)
Mon Nov 20 09:50:09 2023 user.notice mwan3[6304]: Starting tracker on interface wgclient (wgclient)
Mon Nov 20 09:50:12 2023 user.info mwan3rtmon[4918]: Detect rtchange event.
Mon Nov 20 09:50:32 2023 user.notice mwan3[8402]: Execute ifdown event on interface wgclient (unknown)
Mon Nov 20 09:50:37 2023 user.notice mwan3[9694]: Execute ifdown event on interface wgclient (unknown)
Mon Nov 20 09:50:49 2023 user.notice mwan3[11007]: Execute ifup event on interface wgclient (wgclient)
Mon Nov 20 09:50:49 2023 user.notice mwan3[11007]: Starting tracker on interface wgclient (wgclient)
Mon Nov 20 09:50:53 2023 user.info mwan3rtmon[4918]: Detect rtchange event.
AND
root@GL-A1300:~# logread -e wg
Mon Nov 20 10:00:00 2023 daemon.notice netifd: Network device ‘wgclient’ link is down
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Section @zone[1] (wan) cannot resolve device of network ‘wan6’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Section @zone[1] (wan) cannot resolve device of network ‘wwan’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Option ‘wgclient’.masq6 is unknown
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Option ‘ovpnclient’.masq6 is unknown
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Section ‘block_dns’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Section ‘safe_mode_mark’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Section ‘safe_mode_mark_save’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Section ‘safe_mode_mark_drop’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Option ‘sambasharewan’.dest_proto is unknown
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Section ‘sambasharewan’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Option ‘sambasharelan’.dest_proto is unknown
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Section ‘sambasharelan’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Option ‘glnas_ser’.dest_proto is unknown
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Section ‘glnas_ser’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Option ‘webdav_wan’.dest_proto is unknown
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: Section ‘webdav_wan’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Clearing IPv4 filter table
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Clearing IPv4 nat table
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Clearing IPv4 mangle table
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Clearing IPv4 raw table
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Populating IPv4 filter table
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘Allow-DHCP-Renew’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘Allow-IGMP’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘Allow-IPSec-ESP’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘Allow-ISAKMP’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘Allow-DHCP’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘Allow-DNS’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘block_dns’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘safe_mode_lan’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘safe_mode_guest’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘safe_mode_mark_drop’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule #17
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule #18
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule #19
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule #20
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Zone ‘lan’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Zone ‘wan’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Zone ‘guest’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Populating IPv4 nat table
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Populating IPv4 mangle table
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘process_mark’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘safe_mode_mark’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘safe_mode_mark_save’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Populating IPv4 raw table
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): - Using automatic conntrack helper attachment
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Clearing IPv6 filter table
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Clearing IPv6 nat table
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Clearing IPv6 mangle table
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Populating IPv6 filter table
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘Allow-DHCPv6’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘Allow-MLD’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘Allow-ICMPv6-Input’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Rule ‘Allow-ICMPv6-Forward’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Populating IPv6 nat table
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: fw3_ipt_rule_append(): Can’t find target ‘prerouting_lan_rule’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: fw3_ipt_rule_append(): Can’t find target ‘postrouting_lan_rule’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: fw3_ipt_rule_append(): Can’t find target ‘prerouting_wan_rule’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: fw3_ipt_rule_append(): Can’t find target ‘postrouting_wan_rule’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: fw3_ipt_rule_append(): Can’t find target ‘prerouting_guest_rule’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: fw3_ipt_rule_append(): Can’t find target ‘postrouting_guest_rule’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: fw3_ipt_rule_append(): Can’t find target ‘prerouting_rule’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): Warning: fw3_ipt_rule_append(): Can’t find target ‘postrouting_rule’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Populating IPv6 mangle table
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Set tcp_ecn to off
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Set tcp_syncookies to on
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Set tcp_window_scaling to on
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Running script ‘/etc/firewall.nat6’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Running script ‘/etc/firewall.vpn_server_policy.sh’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Running script ‘/var/etc/gls2s.include’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): ! Skipping due to path error: No such file or directory
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): * Running script ‘/usr/bin/gl_block.sh’
Mon Nov 20 10:08:23 2023 daemon.notice netifd: wgclient (26588): sh: 1: unknown operand
Mon Nov 20 10:08:23 2023 user.notice mwan3[26586]: Execute ifdown event on interface wgclient (unknown)
Mon Nov 20 10:08:24 2023 daemon.notice netifd: wgclient (26588): udhcpc: started, v1.33.2
Mon Nov 20 10:08:24 2023 daemon.notice netifd: wgclient (26588): udhcpc: sending discover
Mon Nov 20 10:08:24 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Mon Nov 20 10:08:27 2023 daemon.notice netifd: wgclient (26588): udhcpc: no lease, failing
Mon Nov 20 10:08:27 2023 daemon.notice netifd: Interface ‘wgclient’ is now down
Mon Nov 20 10:08:28 2023 user.notice mwan3[27443]: Execute ifdown event on interface wgclient (unknown)
Mon Nov 20 10:08:28 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Mon Nov 20 10:08:29 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Mon Nov 20 10:08:30 2023 daemon.notice netifd: Network device ‘wgclient’ link is up
Mon Nov 20 10:08:30 2023 daemon.notice netifd: Interface ‘wgclient’ is now up
Mon Nov 20 10:08:31 2023 user.notice mwan3[28510]: Execute ifup event on interface wgclient (wgclient)
Mon Nov 20 10:08:31 2023 user.notice mwan3[28510]: Starting tracker on interface wgclient (wgclient)
Mon Nov 20 10:08:34 2023 daemon.info dnsmasq[28921]: reading /tmp/resolv.conf.wg
Mon Nov 20 10:08:34 2023 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_1559 group_4525 group_3844 group_7103 peer_8275 peer_8161 peer_4618 peer_7861 CONFIG_cfg030f15_ports=
Mon Nov 20 10:08:35 2023 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
Mon Nov 20 10:10:00 2023 daemon.notice netifd: Network device ‘wgclient’ link is down
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Section @zone[1] (wan) cannot resolve device of network ‘wan6’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Section @zone[1] (wan) cannot resolve device of network ‘wwan’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Option ‘wgclient’.masq6 is unknown
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Option ‘ovpnclient’.masq6 is unknown
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Section ‘block_dns’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Section ‘safe_mode_mark’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Section ‘safe_mode_mark_save’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Section ‘safe_mode_mark_drop’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Option ‘sambasharewan’.dest_proto is unknown
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Section ‘sambasharewan’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Option ‘sambasharelan’.dest_proto is unknown
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Section ‘sambasharelan’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Option ‘glnas_ser’.dest_proto is unknown
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Section ‘glnas_ser’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Option ‘webdav_wan’.dest_proto is unknown
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: Section ‘webdav_wan’ does not specify a protocol, assuming TCP+UDP
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Clearing IPv4 filter table
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Clearing IPv4 nat table
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Clearing IPv4 mangle table
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Clearing IPv4 raw table
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Populating IPv4 filter table
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘Allow-DHCP-Renew’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘Allow-IGMP’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘Allow-IPSec-ESP’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘Allow-ISAKMP’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘Allow-DHCP’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘Allow-DNS’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘block_dns’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘safe_mode_lan’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘safe_mode_guest’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘safe_mode_mark_drop’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule #17
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule #18
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule #19
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule #20
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Zone ‘lan’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Zone ‘wan’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Zone ‘guest’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Populating IPv4 nat table
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Populating IPv4 mangle table
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘process_mark’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘safe_mode_mark’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘safe_mode_mark_save’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Populating IPv4 raw table
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): - Using automatic conntrack helper attachment
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Clearing IPv6 filter table
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Clearing IPv6 nat table
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Clearing IPv6 mangle table
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Populating IPv6 filter table
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘Allow-DHCPv6’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘Allow-MLD’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘Allow-ICMPv6-Input’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Rule ‘Allow-ICMPv6-Forward’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Populating IPv6 nat table
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: fw3_ipt_rule_append(): Can’t find target ‘prerouting_lan_rule’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: fw3_ipt_rule_append(): Can’t find target ‘postrouting_lan_rule’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: fw3_ipt_rule_append(): Can’t find target ‘prerouting_wan_rule’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: fw3_ipt_rule_append(): Can’t find target ‘postrouting_wan_rule’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: fw3_ipt_rule_append(): Can’t find target ‘prerouting_guest_rule’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: fw3_ipt_rule_append(): Can’t find target ‘postrouting_guest_rule’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: fw3_ipt_rule_append(): Can’t find target ‘prerouting_rule’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): Warning: fw3_ipt_rule_append(): Can’t find target ‘postrouting_rule’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Populating IPv6 mangle table
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Set tcp_ecn to off
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Set tcp_syncookies to on
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Set tcp_window_scaling to on
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Running script ‘/etc/firewall.nat6’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Running script ‘/etc/firewall.vpn_server_policy.sh’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Running script ‘/var/etc/gls2s.include’
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): ! Skipping due to path error: No such file or directory
Mon Nov 20 10:15:48 2023 daemon.notice netifd: wgclient (17165): * Running script ‘/usr/bin/gl_block.sh’
Mon Nov 20 10:15:49 2023 user.notice mwan3[17164]: Execute ifdown event on interface wgclient (unknown)
Mon Nov 20 10:15:49 2023 daemon.notice netifd: wgclient (17165): sh: 1: unknown operand
Mon Nov 20 10:15:50 2023 daemon.notice netifd: wgclient (17165): udhcpc: started, v1.33.2
Mon Nov 20 10:15:50 2023 daemon.notice netifd: wgclient (17165): udhcpc: sending discover
Mon Nov 20 10:15:50 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Mon Nov 20 10:15:53 2023 daemon.notice netifd: Interface ‘wgclient’ is now down
Mon Nov 20 10:15:53 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Mon Nov 20 10:15:54 2023 user.notice mwan3[18236]: Execute ifdown event on interface wgclient (unknown)
Mon Nov 20 10:15:55 2023 daemon.notice netifd: Network device ‘wgclient’ link is up
Mon Nov 20 10:15:55 2023 daemon.notice netifd: Interface ‘wgclient’ is now up
Mon Nov 20 10:15:55 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Mon Nov 20 10:15:56 2023 user.notice mwan3[19250]: Execute ifup event on interface wgclient (wgclient)
Mon Nov 20 10:15:57 2023 user.notice mwan3[19250]: Starting tracker on interface wgclient (wgclient)
Mon Nov 20 10:15:59 2023 daemon.info dnsmasq[19596]: reading /tmp/resolv.conf.wg
Mon Nov 20 10:15:59 2023 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_1559 group_4525 group_3844 group_7103 peer_8275 peer_8161 peer_4618 peer_7861 CONFIG_cfg030f15_ports=
Mon Nov 20 10:16:01 2023 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
root@GL-A1300:~#
. . . not sure if that is helpful, but there it is.
Wild. I’d just go ahead & disable Multi-Wan via ‘Enable Internet Status Tracking’ for all three entries via the cog icons & reboot. If that doesn’t to it, I’d defer to @hansome .
Nope. Disabling Multi-Wan via ‘Enable Internet Status Tracking’ for all three entries didn’t work either.
Here is the log:
Mon Nov 20 10:44:37 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Mon Nov 20 10:44:44 2023 daemon.notice netifd: Network device ‘wgclient’ link is up
Mon Nov 20 10:44:44 2023 daemon.notice netifd: Interface ‘wgclient’ is now up
Mon Nov 20 10:44:49 2023 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_1559 group_4525 group_3844 group_7103 peer_8275 peer_8161 peer_4618 peer_7861 CONFIG_cfg030f15_ports=
Mon Nov 20 10:45:49 2023 user.notice mwan3[9653]: Execute ifup event on interface wgclient (wgclient)
Mon Nov 20 10:45:49 2023 user.notice mwan3[9653]: Starting tracker on interface wgclient (wgclient)
Mon Nov 20 10:45:52 2023 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
Mon Nov 20 10:50:00 2023 daemon.notice netifd: Network device ‘wgclient’ link is down
It died in under 5 minutes again :-/
Am I the only one having the issue with this device and WG?
Factory Reset maybe just to see if that would help?
Yeah, I’d nuke it all at this point. Fire is the cleanser!
Just use the Firmware reset?
Will that reset all default packages, etc, etc?
Is there a way to export a configuration file so save time in getting set back up?
. . . I don’t see one.
Yep; GL GUI → Reset Firmware.
NO SURVIVORS!!!11!!eleventy!1!!
:rofl:
Well, THAT seemed to do the trick.
I must have gotten ahead of myself.
When I received the GL-A1300 I had scrolled through all of the menu items.
I remember selecting the Plugins and scrolling through what was there.
I also remember seeing:
wg-installer-client
> wg-installer-server
> wg-installer-server-hotplug-babeld
> wg-installer-server-hotplug-olsrd
NONE of them were installed, and so I thought, “I might as well install them”.
Then it was a couple of days before I got back to adding the WG configuration files.
After the reset, THOSE plugins were NOT installed, and now everything seems fine - up for over 25 minutes now and not a hiccup. :partying_face:
I am guessing there must have been a conflict with those added on some how.
Hopefully that helps someone going forward.
Now that you've a fresh 'baseline' to build upon, I'd suggest:
Thanks for all the replies everyone.
It was very much appreciated.
