I have a very simple problem. Port forwards from Basic Settings do not work at all. I must go to Advanced Settings (luci) and add them there to get them to work. They should work in either location. Obviously this is a bug, because otherwise why have port forwarding even available in Basic Settings? Please fix this.
What is the firmware version?
Current Version
3.025
Compile Time
2019-06-26 11:15:03
I conducted a simple test and the port forwarding function worked normally.
Can you describe more details?
What info are you wanting?
I want to know your procedure and the port you set
