Nothing abnormal about the interrupt.
My colleague told me it may be related to hardware acceleration.
Please check if there’s a firewall rule like this:
uci show | grep ‘offloading’
firewall.@defaults[0].flow_offloading=‘1’
firewall.@defaults[0].flow_offloading_hw=‘1’
this had no impact
uci set firewall.@defaults[0].flow_offloading_hw='0'
uci commit
/etc/init.d/firewall restart
firewall.@defaults[0].flow_offloading_hw=‘0’
but this was even slower than current (maybe that’s expected)
uci set firewall.@defaults[0].flow_offloading='0'
uci commit
firewall.@defaults[0].flow_offloading=‘0’
not sure if any of the above are the correct steps to mitigate, but wanted to try something, not sure if needs reboot between changes (would take longer to test)
What do you have for Active Connections in LuCI → Status → Overview? I increased the max limit considerably for the Slate AX’s 393MB. OWRT 23.05.x now calculates a respectable value automatically… but we’re not yet on mainline.
root@slateax:~# cat /etc/sysctl.conf
# Defaults are configured in /etc/sysctl.d/* and can be customized in this file
net.netfilter.nf_conntrack_max=32768
/etc/init.d/firewall {stop, start &/or restart} should do it.
So I’m just going to drop this note before I forget w/ other things going in life.
You can change interface parameters using ethtool. In this particular case I’d disable auto negotiation & force the interface to a strict 1000mb/s. The trouble is I’ve never had need to use this tool as I’ve never had a interface fail like what you describe so I’m not 100% sure of the specific command string needed to disable auto-neg and force 1Gb full-duplex. It could be as simple as ethtool --change eth0 speed 1000 duplex full autoneg off per the die.net manual page.
Once you find it, added it to /etc/rc.local to set it on boot. IDK what the root cause may be on your device/network but this should be a viable workaround. Spot checking w/ OpenSpeedTest might be prudent.
For comparision’s sake here’s the output on my Slate AX running f/w 4.4.6-release1. IDK how much of a difference there is in our respective devices:
root@slateax:~# ethtool eth0
Settings for eth0:
Supported ports: [ TP AUI BNC MII FIBRE ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: external
Auto-negotiation: on
Link detected: yes
I would still try to disable your Opal’s link auto-negotiation + force 1Gb & see how that goes. A quick reboot/power cycle is all it would take to revert it.
@admon What f/w are you running on your Opal? This isn’t expected behaviour, is it?
If the Cat 5 is good & within length limits I’m tempted to start thinking this is some sort of ‘power saving’ BS if not a bug in the Siflower SDK. That’s speculation of course.
Newest beta and no, this isn’t expected nor the case on my device.
We should try to understand if the WAN or switching capacity is the problem. Could you enable Wi-Fi and doing some Wi-Fi ↔ LAN speedtest when the speed is reduced?
I have an “ifdown wan lan && ifup lan wan” cronjob scheduled, which keeps the speed up but takes the network offline for 10 seconds. It’s set for once an hour as a very temporary solution, since this actually disrupts the network and drops connections.
Looking for others out there, I found this Reddit post which sounds very familiar. So maybe others out there are indeed experiencing this exact issue.
My firmware is the same as the reddit post, I had upgraded to latest available prior to posting (prior to my first post in this thread). I’m also running firmware version 3.216, OpenWrt reports version 18.06
Have you tried the latest firmware, 4.3.7? After seeing your thread and checking firmware I realised I was still running 3.x and wondered if possibly it had been addressed. Weirdly the firmware doesn’t show up on the router as an upgrade and when you manually install it, the verification process before install says it’s older and isn’t recognised. I have many of these routers so decided to give it a shot anyway.
It installs absolutely fine and my speeds have been completely fine since. I was actually running a starlink through it and could only get about 80mbps, while getting 300mbps+ through the original starlink router. After putting the firmware on it’s consistant with the starlink router and continual. I was seeing the same issue as you, immediately I could get fast speed but it would drop off quickly after each boot.
Might be worth a shot yeah. Is that still in beta, maybe why it does not show up?
seems to validate (going to wait to test), but also has the warning message “The uploaded firmware is older than the current firmware or is a 3rd-party firmware. It make break the router due to hardware incompatibility. You are also suggested to NOT keep settings.”
Odd, seems both newer and from GLiNet, but maybe not released. I’d also like to keep settings, it’s not a complicated setup.
Yeah I’m not sure. On the firmware page it shows up under stable and doesn’t show up when you select beta. Maybe it’s just been uploaded wrong or something and should be beta?
