Hi, I have dona a reset to default settings and now It works!
I really don’t know why, after flashing It doesn’t work.
But, hot to turn back to original firmware? If I follow the same procedure I cannot enter in the upgrading firmware page… (using the same Guide mentioned above…)
Edit: another thing, Now Tor checker say my network is Tor compliant, but I cannot access to some Onion sites like (You need Tor network to access):
Maybe you have reserved the config files when you upgrade. reset the router clears the config files.
If you want to go back, you can connect your computer to ssid “openwrt” and then you will be able to access http://192.168.8.1/cgi-bin/luci, there will be a UI to reflash the firmware.
For onion sites, I have tried some. I used tor browser and the mini router and achieved the same result. Some sites are unable to connect. Maybe they are down?
