(SOLVED) Slate GL-A1300. Previously working 20tb WD External suddenly not shareable as SMB after reformatting
Windows 10 22H2 is the computer OS I'm using.
The 20tb drive was working fine as an SMB share thru the Slate until I hooked it up to my laptop (Windows 10 22H2) and reformatted it to get rid of a Nextcloud glitch and copy a bunch of files over USB 3. The drive is working fine when hooked directly to a computer.
But now when I hook it to the Slate via a powered hub with four other external drives (the 20tb worked fine over SMB before), the 20tb shows in the Disk Management section under Network Storage (although not accurately reporting the space available - it's got over 15tb free). The other drives' free space appears to be reported accurately, and are successfully shared.
But the 20tb is not in the list of drives that can be shared when I try to add it under the Add Shared Folder dialog.
This was working fine before, so what gives? Drive permissions issue? It must have something to do with its reformatting, but I did nothing unusual for that - just the default Windows settings (NTFS).
Samba is installed as confirmed over SSH:
root@GL-A1300:~# opkg list-installed | grep samba
samba4-libs - 4.14.12-2
samba4-server - 4.14.12-2
samba4-utils - 4.14.12-2
Here's how things look under the OpenWRT interface:
Any help greatly appreciated!
Are you sure it's NTFS and not exFAT? Please double check on a Windows PC.
100% certain the 20tb is formatted as NTFS.
Aha! Checked the system log after hitting the "mount attached devices" button in the OpenWRT Mount Points dialog and got this:
Isn't a 2tb limit associated with MBR? I wonder if Windows gave it an MBR formatting?
Hmm. Maybe I need to reformat using a WD utility or something, or maybe use exFAT.
Formatting won't change partition style.
Follow this: Change a Master Boot Record (MBR) into a GUID partition table (GPT) disk
Bah, Windows claims it's a GPT disk!
I'm at a loss now...
Do you want to use the disk in Windows as well or just router?
I was hoping to access the disk over windows exclusively, yes.
From what I've been reading, the Slate has a 32-bit processor, which limits NTFS volume sizes.
I have ntfs-3g installed and updated on the router, and it sees & writes to my 8tb volume with no problem. But it seems to choke on a 20tb NTFS volume.
Guess I'll be reformatting as exFAT!
My guess after learning this is that the drive was formatted as exFAT out of the box (I never looked to see), which is why it worked initially. My reformatting to NTFS has to be what hosed its mountability by the Slate.
Will update this thread after copyover of files, reformat to exFAT, and copyback (probably take 12 hours) to let y'all know how it goes.
exFAT solved the issue. Reformatting the 20tb drive as exFAT made it shareable over SMB again.
Lesson learned!
If you don't need to use the drive via USB directly on your PC it might be better to choose ext4 as file system since it's linux native.
Thanks for coming back with the solution!
You're welcome, but not so fast - while exFAT solved the issue from a technical standpoint, it caused my space on disk to double with Windows setting the minimum block size to 8 megabytes!
Even when I reformatted it to have a 2mb block size (apparently the minimum Windows will recognize on an exFAT volume) the folder bloat was unacceptable.
So in the end, I simply split the drive up into three NTFS partitions (6, 6, and 7 tb) and they're all being recognized by the Slate just fine. Dunno why I wasn't smart enough to think of that sooner, but my wife did and suggested it, thank goodness.
I did try ext4, but there were no reliable ways to do that from ubuntu command line with Powershell and WLS in Windows - it wouldn't even see the drive. Various formatting tools for Windows didn't work at all.
So I booted the machine into an Ubuntu USB I made today with the most recent version, plugged the drive in, formatted it as ext4, took it over to the Slate and hooked it up. It saw the drive, had the wrong reported size though, and wouldn't let it be shared over SMB.
grr. Oh, well. I ended up using smaller NTFS partitions. Thank you for all your suggestions, though!
As one of our former prime ministers said (you may know who he was) "Life wasn't meant to be easy"
:grin:
