Some devices on Beryl AX cannot acces main network devices
After a fresh install of my new Beryl AX, on repeater mode on my home network, I have an issue.
Some of the devices I connect to the Beryl AX can ping other devices on my home network, but some can not. (Destination Host Unreachable).
I want to know what leads to differents results with differents devices, what should be the default behivior (can ping, or not ?), and what can be done to let all devices access main network devices.
Thanks a lot :slight_smile:
Are all clients on same subnet? VLAN? Wireless SSID?
If on Guest Wi-Fi is AP Izolation on?
Too many variables missing.
Finlay it’s an issue on the device side, not on the router.
On the device, docker has created a network with the same subnet as my home network subnet and with it, a route who break everything.
The solution is to recreate the network with an other subnet. The route is gone. Everything work as expected.
