Sources for building custom V4 Firmware (e.g. for X750 Spitz with GPS support)
i would be happy for a hint where to find the newest (beta) sourcecode for building images…
…the newest firmware in the imagebuilder is 3.217
…:~/imagebuilder/glinet$ git tag |grep x750
v3.217_ap1300/mifi/e750/x300b/xe300/x750
I have searched a lot on the Website, Docs, FAQs but didnt find a actual (V4) repo with the source…
…yes i could go back to V3 but then i could get trouble with the settings and a lot of work with that…
Reason for my question is that i have a GPS antenna on the roof of my RV connected to the mobile-module… of the router… And so i find it stupid to use an extra GPS Tracker…
Thank you in advance for any hints…
Afaik firmware 4.x is closed source now.
You can use imagebuilder from OpenWrt directly.
It is never open source. It is just imagebuilder, which you can use the one from openwrt directly.
Thank you very much for you feedback. I am a little bit sad that i cant use my own openrt base with your gui. To be honest, i dont need the source code. But for example i would have tried to use gl-gps and for sure the gui.
Do you have a hint wgich funktions of you router are normaly functional with a plain openwrt ? (LTE also if its an LTE router)
Best a thank you again
Martin
I don’t get the question tbh.
Nearly all functions (without goodcloud) will work on plain OpenWrt; since that’s what the router is based on.
