Speedtest within Glinet UI
Just for expiramentarion.
If you want to add a speedtest under applications in glinet ui.
ssh in your terminal and run this:
mkdir -p /www/views &&
cat > /usr/share/oui/menu.d/zz-speedtest.json <<'EOF'
"index": 120,
"view": "speedtest",
"title": "Speed Test",
"level": 2,
"parent": "applications",
"parent_icon": "application",
"parent_index": 50,
"show_mode": \["router"\]
EOF
cat > /tmp/speedtest.js <<'EOF'
module.exports = {
render(h) {
return h("div", {
style: {
width: "100%",
height: "100vh",
background: "#000"
h("iframe", {
attrs: {
src: "https://fast.com",
style: "width:100%;height:100%;border:none;"
EOF
gzip -c /tmp/speedtest.js > /www/views/gl-sdk4-ui-speedtest.common.js.gz &&
rm /tmp/speedtest.js &&
rm -rf /tmp/luci-\* /tmp/nginx\* &&
/etc/init.d/nginx restart &&
echo "SpeedTest installed safely."
If you want to remove it
rm -f /usr/share/oui/menu.d/zz-speedtest.json
rm -rf /tmp/luci-\* &&
This would be easier to read if you set the code blocks off beginning and ending with three back ticks
Code goes here
Thanks for sharing your script!
P.S. For better readability and formatting, I’ve edited the original post to wrap the code in code blocks.
This breaks the login I can no longer login to the admin page after I’ve pasted these commands.. delete this or fix it please
