Automatic connection or Manual connection for 5G/4G/3G ?
I’m not sure which one you are referring to:
- Cellular network connection is not automatically activated when you insert the SIM card, you need to go to enable/disable it in the interface. If it is enabled, the Spitz AX will automatically reconnect to the network after a reboot.
- After inserting the SIM card, you can manually set how it connects to the network, or you can have Spitz AX automatically set it up for you. However, we cannot guarantee that all SIM cards from all carriers will be automatically set up successfully.
Cellular - GL.iNet Docs 4 (gl-inet.com)
