I bought a Spitz AX for my RV and it is working great. I am concerned, though, that it is too cold for the device sometimes. I turned it off and brought it home when the temperature looked like it was getting too cold - -5 degrees Fahrenheit (-20 C). Do I need to do that? How cold before I should turn it off, but leave it in the RV? How cold when I should bring it home instead of leaving it turned off in the RV?
If you keep powering on in an environment below minus 20 degrees celsius, there will be no problem, because the chip itself will have heat and will not freeze the router.
If the cold boot is below minus 20 degrees celsius, the device probable to fail to start, as the temperature has exceeded the chip's operating temperature range.
But after the temperature rises, it will still boot/start normally.
Therefore, if the RV stops and the power is cut off, the Spitz AX will turn off, but the environment temperature in the car is warmer after the RV starts, then let the Spitz AX powers on.
This will be good for the device.
If the RV doesn't lose power and the Spitz AX stays running, you don't need to care too much.
