I’d like to have the features from GL-AR750S, but with the option of using a more powerful external antenna.
I see that currently Spitz is the only router you have that supports external replaceable antennas. When in a hotel or campground, free WiFi is often available but sometimes the signal is very weak. I’d like to have the option of replacing the small antenna that the router comes with with a more powerful, directional antenna.
Does Spitz support captive portal pages?
Do you have any other products in your pipeline that support external antennas?
Can the antennas on Spitz be replaced with more powerful ones?
What specs antennas is Spitz compatible with?
Would any of these antennas work just fine?
Thanks!
