Is there a way to disable the SIM in the Spitz without taking the SIM out?
Just “disconnect” the SIM connection .
You can then start another connection via WAN or Wifi.
When you want to use the LTE connection again just disconnect your WiFi/Lan and hit Auto or Manual Setup .
