Splitz AX HW accel?
What does hardware acceleration do on the Splitz AX X3000? Improve wifi throughput? Lowers latency?
Also What’s the difference between:
  • HW acceleration enabled
  • SW acceleration enabled
  • Off
I can understand there being HW and off, but what does SW do?
Just Google it and you will get a faster more accurate details !
Anyway, if you need to test it, always disable it from GL admin panel and enable it from LuCi.
