SSH on Beryl
Hello there! I want to connect to Openvpn with SSH tunneling using Beryl. I use Perfect Privacy VPN and followed their guideline but couldn’t connect to SSH. I’ve installed the necessary packages for SSH and Putty with terminal codes but failed to connect. Is there any easy way to connect to SSH by simply entering SSH host, port, username and password provided by the Perfect Privacy VPN? I can easily connect using Napstertv on ios, but on Beryl it was supper complicated to write terminal codes, enter credentials and finally failing to connect :frowning: I want to use SSH direct on Luci, is it possible?
