Hi all, I need a step by step guide to update ar300m uboot to latest using usb console. If there is any video that would be welcomed. Thanks all
Use UART adapter UART Serial - GL.iNet Docs
use uboot Advanced Uboot - GL.iNet Docs
set up tftp server on your windows
You need to set up a tftp server. In Windows, we recommend tftpd32 or tftpd64 according to your system architecture. Download them from junin.net.
In Linux, we recommend tftpd-hpa. Just search google for a guide to use this tool.
- flash uboot
First put uboot for ar300m in your tftp server. It should have a name like uboot-for-ar300m.bin or similar
Then use the following command to change uboot
run lu
Note, pls
