doesn’t anyone know?
it is for simple mobile, which uses t-mobile
wont connect
wont connect
will it be better if i get from t-mobile instead of simple using t-mobile?
Did you post info somewhere? or via emails?
Can you send screenshot etc via email to support at glinet.biz
Sometimes certain Telco sim card not supported by the modem, not sure what is your case, you have to verify it with sim cards from other telco
i am original poster. i have no screenshot, this is on router.
router gets IP address, it will send and receive texts, it will not get data. it will send data, but nothing is sent back.
I replied you in another thread.
Pls send email to our support we need to get more info.
