Hello all,
just bought a Brume MV1000W and wanted to flash stock OpenWrt 21.02-rc1 (the filename is openwrt-21.02.0-rc1-mvebu-cortexa53-glinet_gl-mv1000-squashfs-sdcard.img.gz) or the snapshot version on it, but when I try to run sysupgrade i get (same error with both firmware images):
root@GL-MV1000:~# sysupgrade -v -n openwrt-mvebu-cortexa53-glinet_gl-mv1000-squashfs-sdcard.img.gz
Image not in /tmp, copying...
Device gl-mv1000 not supported by this image
Supported devices: glinet,gl-mv1000
Image check 'fwtool_check_image' failed.
root@GL-MV1000:~# sysupgrade -F -v -n openwrt-mvebu-cortexa53-glinet_gl-mv1000-squashfs-sdcard.img.gz
Image check 'fwtool_check_image' failed but --force given - will update anyway!
Commencing upgrade. Closing all shell sessions.
"error": {
"message": "Firmware image is invalid"
Command failed: Operation not supported
root@GL-MV1000:~#
Why? Am I using the wrong image? Is the official GL-iNet version the only supported version? I’d like to run stock OpenWrt. I hope I don’t have to return it, as I really like the little router.
Thanks!
