"Stutter" every second on Comet
Have you noticed that the stream “stutters” every second or so? Try to stream a video for instance, or something a bit more demanding than just a text-based app, it’s very obvious, especially at higher resolutions and quality. The stream will hang for a tiny bit every second or so, which is very annoying. Tested with all browsers out there, on a local 10G network so no remote access only direct access, with direct h.264 and 2 different comets. Webrtc is worse so I won’t even go there.
It looks like some process is doing something every second or so and is robbing all CPU for a very short amount of time.
In 1.7 firmware, there is a new function of modifying Video mode.
In smart mode, latency may increase, but it will not cause periodic stuttering.
We are actively testing the beta firmware and will release it shortly on the forum. Thank you for your patience.
Please kindly wait.
Will wait, thanks for the followup
