Hi, I’m Emmanuel Milian. After extensive research and hours of technical testing, I’ve bypassed AT&T Fiber's throttling. My speed used to drop to 0.08 Mbps when using the VPN; now, I can download 42 MB in less than a minute.
Problem Context:
Previously, I used the VPN with standard configuration files, but the connection was unstable. I faced constant drops and immediate blocks from AT&T. The ISP detected the VPN traffic instantly and throttled the speed down to 0.08 Mbps. No external .conf file or imported key provided a stable connection.
The Setup Process (Mullvad Web Panel + Router):
The key to stability was configuring the client directly on the device instead of using external files. I tested 4 different configurations in the Mullvad web panel to find the specific steps that bypass AT&T's inspection:
VPN Settings (Web): Kept DAITA OFF and Multihop OFF to avoid protocol conflicts.
DNS Settings: Enabled "Use custom DNS server" (Google 8.8.8.8 and 8.8.4.4).
Server IP override: Do not change anything here.
WireGuard Port: Do NOT leave it on Automatic! Manually select 51820 or 53.
WireGuard Obfuscation: Enabled Shadowsocks and manually set Port: 443. Kept the rest on automatic and QUIC OFF.
API Access: Everything accepted with no additional configuration.
Once the web profile was ready, I performed a manual login on the router using the built-in Mullvad (G7) profile (using a Canada server as an example).
Critical LuCI Adjustment:
To keep the tunnel stable, I had to go into the advanced LuCI interface (Network -> Interfaces -> WG_CLIENT) and manually set the MTU to 1280. The basic GL.iNet dashboard is too simplified and lacks the precision required to stabilize the tunnel under AT&T's network restrictions.
Constructive Feedback for GL.iNet:
I believe the current software could be much more open and flexible. For a powerful router like the MT6000, the standard UI should allow these advanced tweaks without forcing users to navigate through LuCI. Currently, the system feels somewhat limited when dealing with complex connectivity issues from strict ISPs. My suggestion is to integrate more technical customization options into the main dashboard so that users don't always need advanced knowledge of the router's deep interface to get results.
That is all from my side. I hope this helps the community, and I would love to be mentioned on your social media or official channels for this contribution. Cheers!
Hola a todos, mi nombre es Emmanuel Milian. Tras una extensa investigación y muchas horas de pruebas técnicas, logré superar el bloqueo de AT&T Fiber. Mi velocidad caía drásticamente a 0.08 Mbps al usar la VPN; tras los ajustes, logré descargar 42 MB en menos de un minuto, recuperando la estabilidad de la línea.
Contexto del Problema:
Anteriormente, utilizaba la VPN con archivos de configuración estándar, pero la conexión era un desastre. Sufría caídas constantes y bloqueos inmediatos por parte de AT&T. El ISP detectaba el tráfico de la VPN al instante y "tumbaba" la velocidad hasta dejarla inutilizable (0.08 Mbps). Ningún archivo .conf o "llave" importada funcionaba de forma estable.
El proceso de configuración (Panel Web de Mullvad + Router):
La clave para la estabilidad fue dejar de usar archivos externos y configurar el cliente directamente en el equipo. Realicé 4 configuraciones diferentes en el panel web de Mullvad hasta dar con los pasos específicos que engañan la inspección de AT&T:
VPN Settings (Web): Dejé DAITA en OFF y Multihop en OFF. Esto evita conflictos que el gateway de AT&T detecta y bloquea.
DNS Settings: Activé "Use custom DNS server" con los de Google (8.8.8.8 y 8.8.4.4).
Server IP override: No tocar nada aquí.
WireGuard Port: ¡No lo dejen en Automatic! Seleccionen manualmente 51820 o 53.
WireGuard Obfuscation: Activé Shadowsocks y fijé el Port: 443. Resto en automático y QUIC en OFF.
API Access: Todo aceptado sin configuraciones adicionales.
Con el perfil listo en la web, hice el login manual en el router usando el perfil **Mullvad (G7)**integrado (usando como ejemplo un servidor en Canadá).
Ajuste Crítico en LuCI:
Para que el túnel no se rompiera, fue necesario entrar a la interfaz avanzada LuCI (Network -> Interfaces -> WG_CLIENT) y ajustar manualmente el MTU a 1280. El panel básico de GL.iNet es demasiado simplificado y no permite aplicar este nivel de precisión necesario para estabilizar la conexión bajo las restricciones de red de AT&T.
Sugerencia Constructiva para GL.iNet:
Considero que el software actual podría ser mucho más abierto y flexible. Para un router potente como el MT6000, la interfaz estándar debería permitir estos ajustes avanzados sin obligar al usuario a navegar en LuCI. Actualmente, el sistema se siente algo limitado para resolver problemas complejos de conectividad con ISPs exigentes. Mi sugerencia es que integren más opciones de personalización técnica en el panel principal para que no todo dependa de tener conocimientos avanzados en la interfaz profunda del router.
Sin más, me despido. Espero que esto haya sido de gran ayuda para la comunidad y ojalá logren mencionarme en sus redes sociales o canales oficiales por este aporte. ¡Éxito!
