Subject: GL-MT6000 (Flint 2) — eMMC/GPT corruption, firmware won't persist after reboot, need recovery file
I own a GL-MT6000 (Flint 2) router. After a failed firmware update attempt via the web panel, the router stopped booting normally and would not stay in U-Boot recovery mode via the button/LED method (192.168.1.1 became unreachable, ping returned "Destination host unreachable").
I connected via UART (GND/TX/RX, 115200 8N1) and was able to access the U-Boot console. Using the mtkupgrade command, I was able to reach the U-Boot Web UI and upload a firmware image successfully — the router booted, the web panel loaded, and I could set an admin password. However:
Internet/WAN connectivity did not work in this session
After power-cycling the router (unplugging), everything reset back to the broken state — the firmware does not persist
This behavior matches reports I found of eMMC GPT/partition table corruption on this model (similar to forum thread "Bricked (GPT Corruption?) & Physically Obstructed UART (2026 EU Model)"). It seems the firmware is loading/running from RAM but not being written persistently to eMMC.
Could you please help by providing a GPT/eMMC recovery file for the GL-MT6000, similar to what was provided in that case? I have working UART access and can follow instructions to flash it via U-Boot console or Web UI.
Router details:
S/N: cb6af3f589b52160
Model: GL-MT6000 (Flint 2)
Current firmware attempted: 25.12.5 (r33051-f5dae5ece4)
UART: confirmed working, can access U-Boot console
Symptom: firmware boots temporarily from RAM, does not persist after power cycle
Thank you for your help.
We have sent you the download link for the relevant files and instructions via private message. Please check your inbox.
Hey can you send me the files for a fresh clean start as well? I have a working uart connection.
[ 1.132206] mmc0: new HS400 MMC card at address 0001
[ 1.138061] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 1.143594] GPT:Primary header thinks Alt. header is not at the end of the disk.
[ 1.151077] GPT:1 != 15269887
[ 1.154031] GPT:Alternate GPT header not at the end of the disk.
[ 1.160031] GPT:1 != 15269887
[ 1.162985] GPT: Use GNU Parted to correct GPT errors.
[ 1.168140] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 1.173474] mmcblk0boot0: mmc0:0001 8GTF4R 4.00 MiB
[ 1.179139] mmcblk0boot1: mmc0:0001 8GTF4R 4.00 MiB
[ 1.184235] mmcblk0rpmb: mmc0:0001 8GTF4R 512 KiB, chardev (250:0)
Thanks a lot!
Thorny
Thanks for providing the UART log.
Is it pssible to have the file also, i have this when in the Puty terminal
