Hi folks!
I'm curious if there are any plans to add support for PIA’s DIP (dedicated IP token) to the PIA Wireguard UI config section? In addition to the regular credentials.
GitHub - pia-foss/manual-connections: Scripts for manual connections to Private Internet Access · GitHub is a bunch of official scripts which do support supplying the DIP token. These scripts obtain Wireguard keys and so forth probably in the exact same way the current GL.iNet 4.8 firmware does it, they just have support for that one extra text variable.
If you don't have plans to include this, is there an appropriate place to make a contribution? Like do you keep the provider config flows somewhere in a github repo for example.
I do know I can do this manually using the aforementioned scripts or other scripts by other people, I just want to see if it's a relatively simple matter of adding 1 token and 1 more parameter to the API calls to PIA, because then it would be best to just add it to the UI, even if the field is marked as experimental for some time to lower user expectations and see if it generates extra work for GL.iNet support.
